Introduction: Build a Fiberglass Subwoofer, Start to Finish
    I'm a music enthusiast and have been interested in car audio for a while. I've seen many youtube videos on how to make a custom fiberglass body for a subwoofer. However, I needed to find many different videos to answer all of my questions. Hopefully this how-to will put them all in one place for you. I had acquired two 15 inch PYLE subs and needed to do something with them, so I started researching. I found a cool design from this site :
http://www.tccustomz.com/inc/sdetail/68/96
and went from there.
Here are the specs at a glace:
Specs
- Dual 15 inch Subwoofer Box
- Two PYLE 15 inch speakers
- 1000 watt peak each
- Dual voice coils/ 100 oz magnet
- Custom Fiberglass Front
- Dual port holes tuning box to ~34 herts
- Voice coils in parallel then speakers in series ( aka 4ohm)
Dimensions
- Height 21 inch (top speaker ring)
- Width 20 inch
- Length 37.5 inch
Step 1: Materials List and Project Outline
There's a few stages involved in this particular project:
1) Research and have planned exactly what you want to build. This involves selecting size of speakers, how many speakers, color, port hole location, box tuning frequency.
     - No materials, just time and graph paper
2) Make the wooden body
     - 0.75" Medium Density Fiber Board (MDF Board)
     - Wood glue
     - Clamps
     - Table saw (gives you straighter cuts than hand held)
     - Drill and different sized bits
     - Screws
     - Caulking (I used Liquid Nails)
     - Jig Saw (Most people use a router with a bridge that lets you cut perfect circles, I found my own way)
     - Port Holes
3) Add the fiberglass
     - Fabric Cloth (like Tshirt material)
     - Staple Gun
     - Fiberglass Resin
     - Gloves
     - Paint Brushes
     - Acetone
     - Plastic Containers for mixing
     - WD-40 optional
     - Fiberglass mats
     - Mask for your mouth (fiberglass resin has lots of fumes)
     - Good weather and open area to work in!
4) Add bondo and Sand to make a smooth face
     - Bondo and Hardener
     - Plastic Putty knives
     - Range of sandpaper from about 80 to 400 or more. (An electric sander here helps a ton!)
     - Rounded wood file (looks like a cheese grading tube)
5) The Cosmetics: Paint and add speaker carpeting
     - Spray Paints
     - Speaker Terminal
     - Speaker Carpeting
     - Spray adhesive
     - Exacto knife/ carpenter's knife
6) Wire the speakers and connect to the speaker jack
     - Speakers
     - Mounting Screws
     - Appropriately Gauged Wire
Step 2: Research and Plan
Here are some of the sites I used:
For the design concept which I went from
Port Hole Calculations
http://www.carstereo.com/help/Articles.cfm?id=31
Speaker Enclosure Volume
http://www.bcae1.com/spboxnew2.htm
Easiest-to-follow youtube video of a similar project
http://www.youtube.com/watch?v=G8cz_5eP81U
Step 3: Make the Wooden Box Frame
     All of my pieces of MDF board were cut from a 6'x8' piece. The pictures are straight forward, showing how each piece went together. I used 3 to 5 screws along each flat side of the boards to join them together. Make sure you make a pilot hole first or you will split the MDF board. Also, drill into to wood with a bit wider than your screw head to sink the screw in flush with the flat piece of wood. You don't want to see a bump when the speaker carpet goes on.
     The trickiest part of this step was getting the speaker rings in the position I had in mind. My advice would be to start with one and add another support to that one first and then tweaking the second one. This allows you to make the second one match the position of the first one without trying to get both of them symmetrical at the same time. I used boxes of screws and nails mostly to hold things in place while I used a nail gun to set the rings and supports.
     There's examples of all of this in the pictures.
Step 4: Adding the Fiberglass
     To set up for this step there needs to be something to apply the fiberglass too. For making sub woofer boxes with weird curvatures you need to use a cloth that can both be stretched and strong enough to hold the weight of the drying fiberglass. I found fabric cloth at a crafting store (at first I tried using an XXL Tshirt but it wasn't big enough). First staple the cloth to a ring mount and stretch it to one side and staple it along the edge. Then pull tighter in the mid section to give it cleavage. Then around the second ring, still keeping it tight. Then finish stapling around the last sides. Take a razor blade and cut the fabric away. I 1/4" staples because the MDF board is dense and 1/2" will not go all the way in. Lastly, I had to tap each staple with a hammer to make them sit flush. Because the staples were on the flat sides of the box I needed to make sure they wouldn't show as bumps when I put the speaker carpet on.
     My downfall was using a cloth that was too thin and I could only apply very small amounts of resin at a time. This also lead to lots of bumps and waves in the curvature when the fiberglass was set. I remedied that situation in the next step. I might have gotten around this by stretching is alot more when stapling it, but I would get a thicker material than just Tshirt material next time.
     Using fiberglass can be tough, and I would suggest looking up videos or reading about how to use fiberglass before you start mixing the compounds. At first i mixed too much hardener and the mixture reaction took place so fast that the soda bottle I was using melted in the presence of the reaction. Also, you usually apply this resin with paint brushes. If you want to reuse them each time by cleaning then with acetone keep the following in mind:
          1) clean them well before the resin even begins top harden
          2) don't use those cheap sponge type brushes I got. They might be $2 for a whole pack but the acetone disintegrates the glue holding that foam to that wooden handle. Your then left with a sponge and a stick.
     After 2 layers of fiberglass resin the surface should be strong enough to be able to work with. Now it was time to add the fiberglass mats with resin. When using the mats, rip 6" x 6" squares of the fabric to paste on with the resin. It's better to rip then to cut the mat because by ripping it with your hands the edges are full of strands of fiber glass. This makes for a stronger mold once things have hardened.
Step 5: Bondo and Sanding
     This step takes more time than all of the other steps. The goal here is to create a surface which you can apply a high gloss paint to and make it look amazing. First work in the lowest areas, aka the big dips left from the fiberglass resin. Always keep in mind when you paint the final product, any imperfection will show.  I took a long flat hand sander to keep those speaker rings nice and consistently flat. If you took a piece of sandpaper and tried to make a perfectly flat donut-shape surface, it wouldn't work. This is a good time to cut the cloth out of the speaker and port holes. Any surface bubbles in the fiberglass resin should be cut and filled with bondo. You don't want to sacrifice the structural integrity of this box when you're going to load it with subs and pound on every joint of the thing. Nothing's worse than an annoying rattle when playing music.
      That being said, I suggest using crude sanding techniques first (I used a long thin cylindrical cheese grader like tool to take away high spots quickly). Then use sand paper around 50 grit. Move up in steps of grit until you get to at least 400. Using bondo and sanding it is as much of an art as with using fiberglass. I suggest researching tips and techniques before doing this if you aren't comfortable with it.
Step 6: Painting and Speaker Carpeting
     The next step is to apply the primer and get it ready for a gloss finish. This is where you use a really fine sand grit. Some people use a wet sanding technique (it saves your sand paper from building up too much primer and becoming unusable).
     Use this step to add color to your speaker port holes (I sanded off the worn gold finish and put a flat black on it). I also blacked out the inside of the box. This just makes me happier to think the entire inside is one consistent color, and looks more professional. Also, I had to put the rest of the back wall on the box. I had taken it out to work with the fiber glass before. I cut a circular hole with the jig to fit the speaker terminal and spray painted the inside wall black.
     Once you are content with the primer, go ahead and apply the finish to the face of the box (I only had to paint the curved face because speaker carpeting would cover all of the flat sides). I'm not going to tell you how to spray paint here. I chose white gloss and used 3 layers to make sure the gray primer color wasn't able to show through any point of the face.
     All set to add the speaker carpeting now! This video shows a good way to use speaker carpeting if you're not already familiar.
http://www.youtube.com/watch?v=SHKOtUPKwME. I used the weight of the box to seal the glue and carpet. It's a good idea to use new razor blades, it makes for much cleaner cuts with the carpet. You do not want to use carpeting that is easily stretched and can fray easily.
     The box is done, and the speakers need to mounted and wired. NOTE: This thing will reek of fiberglass resin, bondo, spraypaint, and glue for a long time. Let it outgas in the sun for weeks. I transported the finished product to my dorm room to use shortly after it was finished and it stunk up the car pretty bad.
Step 7: Wire the Speakers
      There are two voice coils for each speaker. I put those coils in parallel and then put both speakers in series to get 4 Ohm overall impedance for an amplifier. NOTE: make sure the internal wiring isn't loose or it will rattle. Also, I was playing with this thing when it was on and it sucked a ping pong ball in through the port hole.
Step 8: DONE!
     I see many comments on similar pages asking if the project is for sale. This particular cabinet I've made is for sale and all earning will go towards my tuition :). It has been used twice in it's lifetime to make sure it works. The first time was to check the speaker connection and the second time was to check the bass. The port holes sucked in a ping pong ball when the speaker cones hit a low note. Also, the lamp shades above the basement floor I tested it in shook back and forth.
      If you're wondering about the costs of materials, I kept track in the spreadsheet. I already had the larger tools readily available. To see the full size picture, click on the i on the picture and then click on "original size (1288x690) 77 KB".
Feel free to ask any questions! I hope you liked the instructable!
