Introduction: Build a Necron Tomb Stalker
For all we know, there are no Necron Titans in the Warhammer 40K world. A little bit ago, a really observant person noticed in a book there was a mention of a great Necron Titan, the Tomb Stalker. There is only ONE concept drawing on the internet, so I had to go off that. So, my fellow Necrons, I want to tell you how to make such a wonderful model, complete with stats.
Step 1: Gathering Materials
I am a fanatic about cardboard. You can do wonderful things with cardboard. So, you will need:
• Cardboard
• Hot Glue
• Paint (Lots of paint)
• Too much time on your hands
• Cardboard
• Hot Glue
Step 2: Prepping Materials
Pull all the tape of your cardboard boxes. Also pull off anything else that would make it hard to paint.
Grab a Exacto knife and some scissors.
Step 3: Making Patterns
Patterns are one of the most important things in the project, since you will be very repetitive.
Legs
Cut a pattern 1 ft by 6 in and cut the corners off ( about an inch in) to make a rectangle with 8 sides.
Upper Leg
Cut a pattern square with the diagonal length the same as the width of your legs. Then, from one corner, go in 2 inches, and cut that corner off. That edge will connect to the leg.
Joint Shields
Here, you cut a hexagon with 1 inch sides. Cut one side in more so you have a dominant side. This side goes "up". It connects to the bottom of the Upper Leg.
Leg Shields
This part is easy. Just cut a trapezoid that will fit within your leg, and it will be placed in the middle.
Body
Grab a large box, about 1 ft by 2.5 ft, and from the top, go in 3 inches, and draw a line down to the bottom corner. Do this on the other side. Do this on the other sides touching the ones you drew, and then cut out the triangles. It will make an angle, kind of like a pyramid. Leave the back alone, since that will be flat.
Back Spines
Cut 4 strips 2 inches by 5 inches. Fold the center inch in a semicircle so it is a curve. Add a small inch by inch trapezoid at the top of each spine. Make 8 small triangles of any small size to put diagonally against the spines.
Roof
Put a roof on your beast that fits your parameters. From the front, go in three inches, and make a fold. This will be a roof door, so you can access stuff from the top.
Head
Make the head lie a Tomb Spyder, but more blocky. Kind of like a sided oval.
Arms
Make two different arms, however you like. Be creative.
Head Shields
These hold the head on. Just two rectangles cut down one side. Can be different depending on how you like it.
Particle Accelerator
The only weapon shown, just make three small triangles.
Legs
Upper Leg
Joint Shields
Leg Shields
Body
Back Spines
Roof
Head
Arms
Head Shields
Step 4: Painting
Step One:
Paint a basic coat, one color. I recommend spray paint.
Step Two:
Add specific details, like hieroglyphics and symbols. Also paint along dominant lines.
Step Two:
Step 5: Stats and Playing
Yay! You finished! Here are the stats so you can scare your friends:
Tomb Stalker - 750pts
Scarabs are simply things, thought of as drones and insects and bugs in the Necron army. Produced by Tomb Spyders, they are diminuitive and easily produced on field.
Tomb Spyders are thought of as the largest non-Tank class Necron on the field. They repair the tombs and the denizens of such tombs. They are giant and powerful, but die easily. But what produces them? Tomb Spyders are not the highest on the food chain. That honour falls to the Tomb Stalker,
The one who PRODUCES the Tomb Spyders...
STATS: WS 10, BS 14, Front 20, Side 22, Rear 22, S 12, I 1, A 6
STRUCTURE POINTS: 3
VOID SHIELDS: 1
CREW: NONE, or a small team, although Crew Stunned does not affect this.
TRANSPORT: Special (Monolith)
EQUIPMENT/WEAPONS/OPTIONS: The Tomb Stalker automatically comes with a total of 2 Titan Close Combat Weapons. These are NOT included in the profile, due to options available. They also mount a Tractor Cannon in their 'mouths', which is directed to the front of the stalker. They also have the following options:- May choose to purchase 2 of the following: Particle Accelerator (FREE), Spyder Tomb (+50pts)
- May choose to replace one/both Titan Close Combat Weapon(s) with a Gauss Flux Arc (-10pts each). These do, however, each affect all ene my units within 30" (In a frontal arc).- May also replace the Tractor Cannon for a Gauss Anihillator (see below) for +100pts.
(Both have 48" range)Gauss Anihillator (Particle) - Strength D, AP 2 - Ordnance D3, Blast/Barrage Particle Weapon
Gauss Anihillator (Beam) - Strength 9, AP 3 - Apocalypse Barrage (3)*, Blast, Melta
(36" range)
Tractor Cannon (Wave) - Strength D6, AP D6+2 (7 or more = -) - Heavy D6 per unit within range, Pinning, Tractor Cannon
Tractor Cannon (Pulse) - Strength 2D6 (10 or more = auto wound), AP D6 - Heavy 2D6, Pinning, Tractor Cannon
SPECIAL RULES: Necrodermis, Necron (yes, it gets WBB), Super Heavy Walker
TRACTOR CANNON ('The Web'): Models hit by this are immediately moved 2D6 either directly toward or away from the Tomb Stalker. Should an enemy moved by this effect assault or be assaulted by the Tomb Stalker in that or the immediate next turn, the Tomb Stalker counts as Initiative 10 (as the target becomes disorientated by the disorientating experience)
PARTICLE WEAPON: See Soulreaper (See Apocalypse board) for details
SPYDER TOMB: Tomb Spyders and their generated Scarab Swarms within 12 inches of the Tomb Stalker count as Necrons for the purpose of Phase Out and We'll Be Back as well. In addition, Tomb Spyders may enter play from the Tomb Stalker (however, this is as if they had deep striked - they may not assault or move on the turn they enter play, and they may not generate Scarab Swarms)
LIVING METAL: Follow rules described for Monolith.
(*: Models under the center of the central blast hole, whether Gargantuan Creatures, Super Heavy, or otherwise are instantly destroyed unless they pass a single Invulnerable Save for every wound they would have taken)
