Introduction: Build a Simple Tachometer at Home
About: Just want to explore the vastness of science and make useful stuffs!!
Hey there, in this instructable I will show you how you can make a simple tachometer at your home, to keep this simple i have given great details with simple explanation that anyone could follow.
What is a tachometer? well to answer this let me explain a situation to you
Imagine you are doing one of your favorite project using a DC motor but you don't know when you power it up at what speed the motor rotates, the rotation usually measured as revolutions per minute is the measurement used in this case.
So when the motor is running the shaft rotates at very fast speed and it is not possible to calculate the rpm by just looking at that so we need some device and this device is called a tachometer.
There is a small catch here you will have to add a small sticker/tape on the rotating part before you point this tachometer and the reason is the sensor needs some reference point that is considered as an obstacle.
What happens in the backend is whenever the ir sensor hits on that sticker it is considered as an obstacle and Every second, calculates RPM from the counter and displays it on the OLED and this conversion is carried out with the help of code that will be fed to the nano.
I wont be revealing all the details here since this might ruin the fun of reading that you will get from the below steps so to begin with i have also given a video in the end that you can watch if you have any questions.
Here is the list of components that you need to build this project
Arduino Nano
OLED display
IR sensor module
Soldering lead and iron
Wire trimmer
Super glue
Hot glue(optional)
DC motor and battery for testing
Few cables that are flexible
3D printer and pla filamament
Slicer
Step 1: Shrink the Size
The first step is to shrink the size! What does this mean might be your question, Well instead of these cable pieces if you just used the jumper wires then the size of the components will be big and the overall size will become bigger and bigger.
I used the wires that I recycled from the nonworking servo motor, These cables serve well for this project and its very flexible.
Start by soldering the wire to the pins directly and make sure there are no any content points that may cause some issues while the project is working.
If necessary you can add a small layer of hot glue to insulate the soldered points.
End of this step you will have OLED and ir sensor that looks like the last image in this step.
Step 2: 3d Design and Printing
I designed the case for this project using Tinkercad it is easy if you are a beginner too you can make some simple designs for your project and make it much more interesting.
I made the base and the lid first and imported the files to Cura slicer, for the slicing I followed the settings given in this step.
There is no need of any rafts or supports at the time of printing, use pla filament and the color is totally left to you
printing time for both the parts combined is less than 2 hours and you can expect very good quality print, end of this step you should have the frame ready.
Step 3: Circuit
The connections are really simple, i wanted to make this project fit in a small box so i soldered the wires to the arduino nano directly, This shrinks the size of the project to a great extent.
We have only 2 components here and i have given the connections below
IR Sensor
Connected to 5V, GND, and digital pin D6 of the nano board
OLED Display
Connected to 3.3V, GND, SCL to A5, and SDA to A4 pins on the nano
This completes your circuit for this project, now you can head over to Arduino ide, connect the nano board to computer and paste this below code
After you click on the upload button the display screen pops up showing the rpm text, now you can simply check the project by just hovering your hand in front of the sensor, The rpm values should change.
This entire setup now will be installed in a 3d printed case and we will see how this can be done.
You also can simplify this circuit with a Simple small PCBComplete your electronic projects in the best way from PCBWay
Why them? They have provided me with the best PCB and The quality is just amazing compared to other providers in the market, They also have Color PCB printing Try it out.
Don't have a 3d printer? You can get the best 3d printing service here
Check Here for Rigid-flex Pcbs with this your circuit becomes flexible! I have added the images to this step kindly check.
A revolutionary solution that combines the best of both rigid and flexible circuitry to elevate your electronic projects to new heights.
With their expertise in advanced manufacturing techniques, they offer a seamless integration of rigid and flexible components, ensuring enhanced reliability, durability, and space-saving benefits.
PCBWay's 10th anniversary is approaching, and there will be a special event in June/July! Stay tuned for exciting offers.
Step 4: Finishing
There is no much work in this step, all you have to do is fix all the assembled electronics inside the 3d printed case.
I have given a slot through which you can provide power to the board using USB cable, follow the placement as i did and place the cover ontop of this and use superglue to couple this together.
make sure there are no wires that come in front of the IR sensor, this is because if there is any obstacle the sensor might give improper results.
Now to use this project all you have to do is power this up with a USB cable and wait for the display to on.
With the help of a battery connect the DC motor and to its shaft attach a small piece of tape and point this device you should instantly see the readings of the rotation.
so why tape? This is because it helps the sensor detect the reflective parts of a rotating object
Like this you can measure the RPM of simple electronics that you will be using in your projects, Thank you for showing interest
Step 5: Video Tutorial
You should not miss the working of this tachometer, i have used battery to power the DVD motor you can replace this motor with any BO or gear motor.
I would not say that this tachometer is highly precise but it does the job, This was all about building this project, if you have any suggestions ask me in the comments and i will reply soon.
Try building this project and you will really be amazed, Thank you and have a great build.
