Introduction: Bumber Plate Rack
About: I prefer wood and metal on my projects but I also have done some Raspberry and Arduino projects.
How to build a simple rack for bumber plates.
Materials:
Wood: 48x98mm Spruce. (~2€/m here)
6mm birch dowels
Tools:
- Miter saw
- Cordless Drill (6mm bit)
- Planer
- Sander
Step 1: Planning
For this type of rack the exact thickness of each weight plate is needed before cutting. The weights in the drawing aren't really the right size except of the thickness.
Step 2: Slot Cutting & Crossbeams
The cutting is quite simple to do if your miter saw has movement limiters. I didn't saw both planks at the same time as the picture above would indicate. The sawing process is best seen in the video.
Step 3: Assembly
I used 6mm birch dowels to hold the construction together. I did not use any glue as I expect the wood to shrink a lot when brought inside.
The slots for the smallest plates are easier to cut very last.
No coating or wood treatment is needed as this is just a tool to keep the plates in place.
