Introduction: Bunny Calendar
About: If its practical, I have no use for it!
My daughter and I made a calendar to count up to someone’s birthday, a special date, or simply use as a regular calendar. We have several family members with a birthday on the 26th, so that’s what we designed for, but obviously you can build it as a 31 day calendar. Also - an Advent Calendar!
1/4" thick hardwood, e.g. cherry, maple, walnut
small 1/8" dowel
wood glue, sand paper
laser cutter or scroll saw
Step 1: Build the Rail
The two scalloped rails were laser-cut from 1/4” thick cherry. Afterwards we cleaned the black-burned edges by sanding. The distance between the valleys is 1 inch. The calendar is 15 inches long.
One rail was engraved with the numbers 1 to 13, the other side has the numbers 14 to 26 engraved. Again, modify to make a 31 day calendar.
The two rails were glued together with a 1/2” by 1/4” by 15” strip of cherry. Sand and finish.
Step 2: The Bunny
The bunny was laser-cut from 1/4” maple. To support it on the rails we used short pieces of 1/8” dowel glued into the two holes.
I have attached the svg files for the rails and the bunny for your use.
Step 3: Enjoy
Each day hop the bunny along the rail as you approach your special date. Turn the rail around after day 13. Hoppy Birthday (or anniversary, holiday, etc.)
