Introduction: CB Install Jeep TJ Safari Project Building the Overland Jeep CB Radio Is EPIC
Please watch the You Tube Video on You Tube and Use the supplies links as it helps support the Instructables I post and share. Thank You Steve
This Epic CB was to cool not to buy!
“As an Amazon Associate I earn from qualifying purchases.”
Uniden CMX760 Bearcat Off Road Series Compact Mobile CB Radio, 40-Channel Operation, Ultra-Compact for Easy Mounting, Large 7-Color Backlit LCD Display on Mic with Built-in Speaker Mic, Black https://amzn.to/3eUqTWK
Nilight 12 Pack 12V Car Add-a-Circuit Fuse Tap Standard Mini Micro2 and Low Profile Fuse Taps 4 Types ATO ATC ATM APM Fuse Holder for Cars Trucks Boats
https://amzn.to/3DkLeOb
KAIWEETS Wire Stripper 10-22 AWG Wire Splicer Cable Stripper Multipurpose Wire Stripping Tool Electrical Wire Pliers with Screw Cutter
https://amzn.to/3zfPBrE
TICONN 200PCS Heat Shrink Butt Connectors Kit, Insulated Waterproof Electrical Marine Automotive Wire Crimp Terminals, Butt Splice (3 Colors / 3 Sizes)
https://amzn.to/3tkjMKV
We install this without drill holes in or Jeep TJ
Step 1: Placing the Mic
Do Not Drill Holes Two sided tape is your friend
Step 2: Mounting CB on the Rear Tool Box Face
Use 3M two sided trim tape
Step 3: Wiring
Using the Fuse jumper we add wires without cutting the factory wires!
Step 4: Put It Together & Test
Works Great, Please Follow me on Instructables and You Tube Thank You for watching
