Introduction: CUP TOP AIR CONDITIONER
I've seen a number of DIY AC units using a Styrofoam cooler, fan and ice. After many years of sweating in the sun watching youth sports, I thought it would be nice to downsize and personalize the concept. So this is for all the dutiful parents supporting their kids - soccer, baseball, swimming, camping, etc. It's not going to blow your hair back, but it's a pleasant, portable cool breeze. STL files included (step 5). Good luck.
Step 1: BASE TUMBLER
For this project I purchased an Ozark tumbler (Walmart - approx. $8)
Interior of cup mouth is 3 11/16" (seems to be a common size)
Step 2: DRILL
To more easily remove the center of the lid for air flow, drill holes around the inner surface as a guide
Step 3: SAW
Connect the holes with a jigsaw to completely remove the center
Step 4: EDGE CLEAN-UP
Clean up the rough edge with a stone grinding tool and light sand paper
Step 5: 3D DESIGN (download)
Using the 3D software of your choice (3DS Max pictured), create the objects needed based on the specs of the tumbler used - fan blades, spout, fan grill and a surface to hold it all together
STL files available for download
Notes:
1) The bottom of the base surface should be flat as it will be attached to the lid for an air tight fit to the tumbler
2) You'll want the fan blades as close as possible to the sides of the intake tube but allow for the shell thickness during printing
3) You'll also want the fan blades positioned well within the tube to get a better draw
4) Mind the ON/OFF switch when creating placement for the battery pack
Step 6: 3D PRINT
Print individual objects (in this case I used a DaVinci miniMaker)
Step 7: ADDITIONAL PARTS
Additional parts needed - 3V motor and AA battery pack (ON/OFF switch included on pack)
Notes:
The motor used was listed on Amazon as: Flormoon DC Motor Mini Electric Motor 3V 8500RPM
With version 2.0, I will probably place/wire a larger, separate ON/OFF switch in the space to the left of the spout
Step 8: MOTOR PLACEMENT
Epoxy the motor into position
Step 9: FAN BLADE
Epoxy the fan blades onto the motor post making sure that the rotation and tilt of the blades will force the air down, into the tumbler (I ran the motor before the epoxy dried to make sure the placement was level)
Step 10: SUPER GLUE SPOUT
Super Glue spout into position
Step 11: ADD FAN GRILL/BATTERY PACK
Super Glue the fan grill and epoxy the back plate of the battery pack into position
Notes:
Make sure epoxy is dry before you replace the cover to the battery pack
Step 12: SOLDER WIRING
Solder wires - red to red, black to black (heat shrink protection optional)
Step 13: ATTACH TO LID
Epoxy the completed unit to the tumbler's lid
Step 14: ADD ICE
Fill 2/3rds of the tumbler with ice
Step 15: ENJOY
Step 16: NOTES:
1) The mouth seems to be the same size as other popular tumblers as well as a number of commercially used cups, so this unit should be able to fit on top of that ice cold Coke while on the go.
2) I do NOT recommend drinking from the spout - the motor and wiring are not protected or waterproof so tipping the cup to drink is probably not the best course. However, the spout I designed is angled such that a straw can fit down through the space.
3) Yes, this version is a bit clunky (more of a proof of concept). I'll be working on something more aesthetic for version 2.0. Thanks for checking it out.
