Introduction: Cactus NightLight!(under 2 Dollars)
Hi
this time i'm going to show you have to make a garden night light under 2 dollars!
so follow the instructions.
Step 1: What Do You Need?
For making this great project you'll need:
about 80 cm of paper tube(found in a roll of carpet)
li-po 3.7v 350mlAh battery
li-po battery charger
small switch
3 highbright LEDs (blue)
12ohm resistor
4 plastic cups
also:
black spray paint
drill
small saw
hot glue
Step 2: Cutting the Tube
mark lines every 10CMs of the tube and cut it slowly
you can also sand the tube after cutting.
Step 3: The Paint Job!
paint it using an spray paint and let it dry
Step 4: Adding the Electronics!
after that you have to make a hole in the pipe to mount it to the wall!
Step 5: You Did It!
now you can add the cactuses and mount it to the wall.
thanks for your attention.
