Introduction: Candy Resin Stool
When ever you in need of a high stool then this is perfect one. it fits a outdoor dining table and it is as easy as pie to make
- just follow the steps
- Take your desired mold and on the inside give it a cote of vaseline.
- Take mold(do not remove the vaseline)and fill it up with 2cm of resin wait 24 hr then add your candy(the side that is up will be seen when you are done)and fill it up with another 2cm of resin(add it slowly so that the pieces will not move) and wait for it to harden.
- Build your desired frame.
- remove the resin from the mold and sand the sharp edges.
- fasten the seat onto the frame.
Step 1:
- Take your desired mold and on the inside give it a cote of vaseline.Take mold(do not remove the vaseline)and fill it up with 2cm of resin wait 24 hr
- add your candy(the side that is up will be seen when you are done)and fill it up with another 2cm of resin(add it slowly so that the pieces will not move) and wait for it to harden.
Step 2: Finish
- and done.
