Introduction: Car Spray Paint for Refinishing Vintage Wood Speakers
So, these are some hand-me-down Yamaha’s I was given by a good friend. Vintage is a joke, they are in no way vintage. They sound good but look a little rough. Let’s fix that!
My inspiration is the AudioEngine A5 bookshelf speaker… except cheaper, amp-less, and red!
This is also a good way to get some practice painting before you paint your motorcycle :)
Step 1: Research - It's What Plants Crave
To figure out how to make the speakers shiny I read this forum over at caraudio.com. Special thanks to user nissanrider06. This is his image.
Check out the next steps for specifics and tips I learned along the way.
Here's the process suggested on the caraudio forums with a few modifications (This part may take a while ;) ):
- bondo
- 80 grit sandpaper
- bondo
- 80 grit sandpaper
- bondo
- 120 grit sandpaper
- 200 grit sandpaper
- 300 grit sandpaper
- primer
- primer
- glazing putty
- 600 grit sandpaper
- metallic coat ( I didn't do this)
- 800 grit sandpaper
- 1000 grit sandpaper
- paint
- paint
- paint
- clear
- clear
- clear
- 1400 grit sandpaper (I added this step)
- 2000 grit sandpaper (I added this step)
Step 2: Filling in the Rough Spots
Here are the speakers masked out, and bondo-ed. I found out I didn’t need to bondo them. Because it wasn’t rough wood or fiberglass, it just wasn’t necessary. So if you have scratches I suggest just using glazing putty.
For masking I just used frog tape and paper found on the painting isle at Lowes.
Step 3: Two Coats of Primer
Here's what they looked like after two coats primer. If you have an indoor workshop your better off doing finishing work inside. I know that's obvious, but I guess I just really like sanding off bugs and grass clippings.
Step 4: Paint!
So here they are after a coat of red. I used Rust-oleum Gloss Protective Enamel paint. Also used Rust-oleum primer and clear coat on this project.
I did way too much research on what kind of paint to use. Unfortunately I don't remember where I got the information from. If I had to guess it was probably at forums.sohc4.net. If I didn't get the info from there, they deserve a shout out. It's an awesome forum especially if your rebuilding a 1970s Honda Motorcycle, but they also have good general information on finishing metal parts.
Step 5: Clear Coat
And here the speakers are after a couple coats of Rust-oleum Clear coat.
Step 6: Finally
And finally… Here are the speakers completed. After the clear I polished with rubbing compound. It really helped shine them up. They are not perfect. From certain angles you can see discrepancies in the clear coat. But they look pretty good.
TL;DR:
- Don’t use Bondo unless it is a really rough surface. Honestly I think it did more harm that good.
- Use glazing putty! It's your friend.
- After you sand the clear, the shine will go away. But the rubbing compound will bring back the shine.
- I didn’t keep track of time, but I would say it was may be 10hrs of work(I’m slow).
- The biggest issue was letting everything dry between coats. So I would work on it a little and then I wouldn’t have a chance to work on it again for a week or two. But now they look and sound good!
- Also friendly piece of advice don't use Goo-Gone on your actual speakers. It will dissolve the glue that holds them together in addition to taking off any goo.
Step 7: Amplitude
I wrote in the introduction, the speakers I would really like to have are AudioEngine amplified bookshelf speakers.
Finding internal amplifiers that would fit into the Yamahas has proved to be a real challenge. There are a lot of subwoofer amplifiers out there, but not many powerful ones for full range speakers.
The closest thing I have come across is a forum post about modding a sub amp into a full range amp on techtalk.parts-express.com(http://techtalk.parts-express.com/showthread.php?184927-Full-range-plate-amps-for-computer-speakers-*PIC*). I haven't had the bandwidth to accomplish this yet though. So if anyone has any tips or suggestions please let me know.
Thanks
Jon
