Introduction: CardBoard Plane: Jet Blue Plane Replica
This project is quite obvious. This is a jetBlue airplane replica. This type of plane is very rare as it was dedicated to the New York City fire department. Keep in mind this is not exact as I had added a few details that I thought made the plane stand out. The main skeleton of this plane is crafted from cardboard with two metal C channel supports. The wings and tail fin are also created from cardboard along with the jet engines. The plane is rapped in paper and painted. Also, the main controller for the lights is located in the cockpit and has wires attached to the wing lights and tail fin light. One more thing, the plain is hand painted. There was a lot of work put into it and took two weeks to build.
I built this plane to show people that a lot of things could be made from cardboard, not just boxes. In fact cardboard is a very useful artistic tool, it just takes the artist to look "outside the box." A man by the name of Albert Szent Györgyi once said "Discovery consists of looking at the same thing as everyone else and thinking something different." This is a very important concept that I want share with everyone. Although creating something from cardboard can look difficult, you will never discover the enjoyment of working with it unless you look out side the box. With that said, I hope you enjoy building this airplane.
lots of cardboard
paper
glue
paint: red, white, and blue
four metal C channels
an Arduino
LEDs: red, green, and white
lots of wire
a 2k resister
overall length: 2 feet
Step 1: Drawing the Pieces
Begin with a large box, about 2 feet tall. Draw out the main shape of the plane and 6 circles with a diameter the width of the plane.
Step 2: Cut It Out
The next step is too cut out the drawings you made in the previous step.
Step 3: Half It
Take each circle you cut out and cut those in half to make 12 half circles (I made a few extra).
Step 4: Metal Time
This step requires two C channels and the shape cut out of the plane. Drill two holes, one in the front and one in the back of the shape cut out of the plane. Attach the two C channels, one on the top and one on the bottom. follow the pictures.
Step 5: Keep Cutting
Take each half circle that you made and cut a square the width and depth of the C channel used.
Step 6: Line It Up
Glue 6 of the half circles onto one of the C channels (it does not matter). Space them out exactly like the picture.
Step 7: Time for the Tail
Next, cut out two tail fins in the exact shape as in the picture
Step 8: Time for the Tail 2
attach the two pieces of the tail fin exactly like the picture.
Step 9: Lets Get to the Bottom Line
For this step, glue four half circles to the bottom C channel and screw a thin strip of cardboard to the back of the plain exactly like the picture. Space the half circles exactly like the picture.
Step 10: Arduino Time
Screw the Arduino controller to the inside of the cockpit. Follow the picture. Attach the USB cord to the Arduino.
Step 11: Designing the Front
Screw a thin piece of cardboard and a small piece of metal the width of the piece of cardboard to the front of the plane to create the shape of the cockpit. Follow the picture presented.
Step 12: Lets Wing It
Cut out and glue the wings to the sides of the plane toward the center. Also cut out a long thin piece of cardboard the length of the C channel. Lastly, cut out a smaller piece of cardboard to shape the bottom side of the nose as presented in the picture.
Step 13: Cover It Up
Cut out 8 thin strips of cardboard the length of the C channel. Lay them across all of the half circles on the top side so that the top is covered completely.
Step 14: Time for Brackets
Screw two L brackets to the top of the tail fin like the image presented.
Step 15: Lets Wing It Again
Make 2 more wings half the size of the previous ones. Screw these to the L brackets that were just attached to the tail fin.
Step 16: Engine Time
In order to make the engines cut out two rectangles and bend them just like the first picture. Create the engines and place them one on each wing as shown in the second image. Also, craft two wide 2 inch thick rectangles the length of the C channel and glue them to the side of the plane right under the wing. Follow the pictures.
Step 17: More Thin Rectangles
Cut out thin strips just like the first image presented. Make another thin strip to go in between the strips previously made. Cut out a longer strip of cardboard and glue it to the underside of the plane as presented in the last picture. Cut the strip so that it is not hanging out and glue the end to the end of the plane.
Step 18: One More Engine
Create an Engine just like the previous two except you need to attach a longer piece of cardboard the width of the engine. Follow the pictures. Attach the engine to the plane just like the second image.
Step 19: LEDs
Place a green and white LED on the right wing and a red and white LED on the left wing. Lastly, place a red LED to the top of the tail fin right in the center.
Step 20: The Circuit
Create the circuit above and place it into the plane. Make sure that the wires are secured to the plane.
Step 21: Time to Test and Tape
Test the lights and circuit to make sure they work and rap tape around the entire plane except for the wings and tail fin.
Step 22: Building the Stand
Take one long C channel and one small C channel and create the stand seen in the last picture.
Step 23: Lets Use Paper
Rap the front of the plane in paper and also add a sheet onto the middle part of the plane. follow the image.
Step 24: Paint It
Paint it just like the images above.
Step 25: The Code
Follow the code in the picture. Download it to your Arduino with the USB cord.
Thank you! If you have any questions please leave them in comment box below. Also, if you can, please tell me what you thought of this project by leaving a comment.
