Introduction: Cardboard Arcade Cabinet
Here I show my completed Cardboard arcade cabinet. I do not have any pictures of the build, but I will tell you the basic idea, then you can built to your liking
Step 1: Gathering Materials
Heres the things you need
-5 or 6 cardboard boxes, the same size is the best, so you should use the boxes that you buy copy paper in. Thats what I used
-An Old CRT television, from 9" to 13"
-A PS 1, PS 2, or xbox
-A Game for that console
-Blue painters tape
-Sharpie
-A box opener blade, xacto, scissors
-Blue painters tape
-Sharpie
Step 2: Building the Base of the Cabinet
First Put the cabinet together how you would like it. Consider all elements, such as where the tv will fit, as well as where the gaming system and cables will go.
This is the way I did it.
I stacked three boxes. I taped them together. I had the third box so the open side was facing out. I cut an opening in the second box for the ps2. I put the tv in the third box, the ps2 in the second. Run the controllers out through a hole in the front., and nothing in the first. I recommend adding re-enforcements in the second box, as this will be where the weight of the tv will make the most torsion on the cardboard.I put another piece of cardboard on top with a piece on top so it looks like the real arcade cabinets. Look at the pics to see what I mean. After this. Insert all of your components, and make sure it works. Next, cover up the back of the tv with another box, as it will be hanging out. Cut a whole in the back of the second box, run the game system cables through there. Cover up to original hole you made for the ps2, then make a smaller one on the back of the second box near the gaming systems power button. Make sure its only big enough for your hand. Nows the hard part. You have to decide whether to cover it with tape or not. I decided to do so. It is harder to spray paint because you have to take all of the components out, spray it, and then put them all back, and when the gaming console starts baking in the enclosed compartment, it might start to smell. So, I just covered the whole thing with painters tape. It looks pretty good. Once you have done all this, Label it with a sharpie, and power it up, and remember to leave it at the "press start" Screen of the game for realism. You can add a coin slot on the front and an hole in the back for retrieving the money. Enjoy your new arcade cabinet!
Step 3: Namcomuseum
I use the Game Namcomuseum for realism as to it being a 1980's gaming machine. Here are some pictures of the games
Have Fun!
Have Fun!
