Introduction: Carton Air Conditioner
Youll need
Any Type Of Carton
scissors or Boxkinfe (to cut the carton)
and any fan that will fit on your carton
Step 1: Step 1: Cut the Cartoon to Fit Your Fan of Your Choosing
I used a fan that I got from my local Speedway. Your can be square or round it does not matter it just needs to fit your size of carton! Also cut a hole to add the ice but don't cut a hole cut a flap so it opens and closes and then secure it with duct tape when using.
Step 2: Step 2: Attach Your Fan Whatever Means Necessary.
I didn't have a hot glue gun but you can attach it with duct tape if you like like i did. Make Sure there is no wiggle room and also make sure that it has a tight seal.
Step 3: Step 3: Add Ice
Add Ice to the flap you cut in the back of the carton then secure it with duct tape
Step 4: Step 4: Your Done :D
Make sure the flap you add the ice into is closed with duct tape. then press the fan on and it should circulate the cold air from the ice out where the lid is. Don't forget take the lid of your cartoon out so the cold air can escape
