Introduction: Cat Clock W/fish
About: I am an artist living and teaching ART in NYC for over 30 years, and I am a CZT, Certified Zentangle Teacher. I love to explore all sorts of art making both in my teaching and in my own work...check out my sit…
Here is a fun and pretty easy clock to make if you have a few tools, glue, and pendulum clock mechanism.
Step 1: Supplies
Pendulum clock mechanism (Amazon)
basswood, thin craft sheets (you can also use foam core)
bandsaw or coping saw
sandpaper
5" circular plaque
air dry clay or equivalent
drill
white primer
acrylic (brushes water etc...)
wood glue, pencil, paper, sharpie marker, scissor, AA battery
Step 2: Design the Clock
First, do a sketch of the clock you want to make. I chose to make a cat with a fish on his tail. Next draw the actual size body parts. Plan on using a base for the animal which also needs to be cut from the basswood. outline the body parts with a sharpie, then cut and place on the base piece to be sure of the size. note that the 5" plaque will become the belly of the beast and also the actual face of the clock.
Step 3: Transfer to Basswood
Using the body parts as templates trace them to the basswood (or foam core, then you would use an exacto blade to cut)
Cut your wood pieces I used a band saw however when I have done this activity with my younger kids they use a coping saw.
sand all edges and spray prime...You do not have to spray prime but I find it is easier to eventually paint.
Step 4: Drill Hole
line the circular plaque and the base piece carefully together and drill a hole through both pieces.
Step 5: Extra Features
I used air-dry clay to mold eyes etc. for my creatures.
Step 6: Paint the Clock
Paint and decorate all the body and clock parts (I decided my cat needed whiskers!) When dry glue all the pieces together (including clay pieces.) When gluing clock face to base be sure the hole lines up exactly. I used wood glue except for gluing the pendulum rod to the fish.
Step 7: Assemble Clock Mechanism
as directed on package.
Step 8: Finished
Insert AA battery and your clock is finished.
Pictured are other animal clocks that I have made.
Also if you take a look at other Instructables I have posted you will see a pretty cool Monopoly Clock!
