Introduction: Chain Mail Trilobite Paracord Bracelet
Hey everyone, today I present to you... The Chain Mail Trilobite Paracord bracelet.
Step 1: Gather Materials
The things you'll need are:
-Paracord
-Stainless steel open jump rings (10mm diameter)
-Snap shackle
You can get the jump rings here: https://www.amazon.com/HOUSWEETY-50PCs-Stainless-Steel-Findings/dp/B015R10C9U/ref=sr_1_1?ie=UTF8&qid=1471229765&sr=8-1&keywords=HOUSWEETY+50PCs+Stainless+Steel+Open+Jump+Rings+10mm+Dia.+Findings
You can get the snap shackle here: https://www.amazon.com/Bracelet-Sailboat-Stainless-Five-Oceans/dp/B00EFEXN4M
Step 2: Making the Setup
Step 1: Cut two pieces of cord, each about 10 feet long
Step 2: Find the middle and make a loop with one of them, then twist the loop
Step 3: Find the middle and make a loop with the other cord
Step 4: Thread the loop into the twisted loop
Step 5: Bring the loop you just pulled down
Step 6: Thread the other side of the cord into the loop, creating a cow hitch
Step 7: Now you'll need the metal jump rings
Step 8: Thread the middle cords through 20-25 rings, you can always add more when your working, and if you have to many you can take them off when you end the bracelet
Step 3: Making the Bracelet
To anyone who read my instructable on the Paracord snake, this should feel familiar because it is the same style of knots.
Step 1: Take the right cord and place it over the middle cords, but under the left cord
Step 2: Bring the left cord under the middle cords and upwards through the loop created by the right cord
Step 3: Slide a jump ring down
Step 4: Make a loop with the right cord around the rightmost middle cord
Step 5: Bring the left cord over-under-over to the right side
Step 6: Bring the right cord over under to the left side
Step 7: Repeat steps 1 through 6 until you reach the end of your cordage
Step 4: Jump Rings
So, I ran out of jump rings because I did not put on enough initially. I will show you how to put them on a different way.
Step 1: Take a jump ring and two pairs of pliers
Step 2: Grab the jump ring with both pliers and give it a little twist
Step 3: Push the ring onto the middle cords from the side
Step 4: Close the ring by using the pliers
Step 5: Ending the Bracelet
Step 1: Take your needle nosed pliers and pull the excess cord through four rows on the side of the bracelet
Step 2: Do the same thing with the other cord
Step 3: Cut off the excess and melt the ends
Step 4: Do the same thing with the other cord
Step 6: Snap Shackle
So you're done and probably thinking "Wait, what about the shackle," so I saved this part for last because it will be easier if we already have the bracelet made.
Step 1: Thread the shackle onto to the two strands
Step 2: Take your needle nosed pliers and pull the cord through four rows on the side of the bracelet
Step 3: Do the same thing on the opposite side of the bracelet
Step 4: Cut and melt both ends
Step 7: Finished!
Congratulations! You've made the Chain Mail Trilobite Paracord bracelet. I hope you enjoyed my instructable and I hope that you will vote for me in the Outside contest!
Thank you for the positive feedback on my other instructables!
