Introduction: Chalkboard Fridge
Give an old fridge a functional facelift!
Our refrigerator died recently and a friend kindly gave us an old fridge to use while we save up for all new appliances.
While the new-to-us fridge is great in the sense that it doesn't make dying animal noises in the middle of the night, it wasn't much to look at, having collected several scratches and scorch marks over its long life.
I remembered seeing a chalkboard fridge on apartment therapy, and decided to give it a go. Painting the fridge turned out to be an easy project that my partner and I were able to accomplish while our son took an afternoon nap.
Step 1: Clean the Fridge
Thoroughly clean the fridge.
Odds are it is disgusting, but even if it looks clean, you'll want to make sure there is no dirt or grease on any of the surfaces you will be painting.
We vacuumed up the dust and crumbs and then washed the inside and outside with wet rags and kitchen cleaner.
Step 2: Remove Trim and Doors
Remove any unwanted decorative trim.
Our fridge doors featured some faux wood trim that we were able to peel off without much trouble as it was only held in place with some sort of adhesive.
Remove the fridge doors and handles (if possible).
Most fridges have doors that are easy to remove, so you can switch them to open on the right or left side, depending on your kitchen. Usually you just need to pop off the hing cover and then unscrew the bolts holding the doors in place.
Our fridge, however, has power running to the door for a temperature-controlled butter dish, so the doors and handles were not designed to be switchable. We considered cutting the power cable to the door, but decided instead to leave it connected and simply paint the door while it was lying in front of the fridge.
Step 3: Mask Off Areas Not Being Painted
Cover anything you do not want painted with painter's tape.
Since our handles were not designed to be removed, we carefully covered them with masking tape. We also taped over the gaskets and inside edges of the doors.
We used newspaper, held in place with more masking tape, to protect the inside of the fridge from paint.
Step 4: Paint
Follow the directions on your paint can.
We used Krylon chalkboard spray paint and are really pleased with the results.
We applied several thin coats of paint after thoroughly shaking the can, and then let it dry. It was dry to the touch in 15 minutes, but we allowed it to fully cure for 24 hours.
Remove the masking tape and put the doors back on.
Enjoy drawing on your newly painted fridge!
