Introduction: Cheap IPad Stand
Step 1: Parts and Tools
You need:
Cardboard
Duck tape
Popsicle stick
Ruler
Scissors
Step 2: Cut
Cut a piece of cardboard 7 inches long and 2 inches wide
Also cut a piece of cardboard that is 6 inches long and 2 inches wide
Step 3: More Cutting
Cut another piece of cardboard that is about 5 inches long and 4 inches wide
Step 4: Even More Cutting
Cut another piece of cardboard that is 1 inch long and a 1/4 inch wide
Step 5: Tape
Cover the part that is 6 inches long and the part that is 5 inches long in Duck Tape
Step 6: Connecting
Now connect the parts that are taped together by using tape and it should look like it does in the picture
Step 7:
Now use a small pieces of tape to connect the 1 inch long pieces of cardboard to the 7 inch long piece and space them 1/2 inch from the end and 1 inch apart
Step 8: Cover
Now cover the part with Duck Tape
Step 9: Connect
Now connect the part you just taped and the other part you taped together by only connecting the square part an inch from the end and add another tab at that end and it should look like the picture
Step 10: Support
Add support the the 6 inch piece of cardboard by adding a Popsicle stick to it and putting tape over it
Step 11: Finished Product
You can adjust the tilt of the IPad by using the other tabs
