Introduction: Chocolate Covered Pretzels
This instrucatables will show you how to make chocolate covered pretzels. Making chocolate covered pretzels is easy and inexpensive. This makes a great dessert for parties!
Step 1:
The ingredients you will need are:
• chocolate
• pretzels
You will also need two knives, a cutting board, and a small bowl. Let's get started.
• chocolate
• pretzels
Step 2: Cut the Chocolates
Cut the chocolates into small pieces. It's up to you how much chocolate you use. I was able to make about 10 pretzels with three pieces of chocolate.
Step 3: Melting the Chocolate
Melt the chocolate in your microwave for about 1 minute. I melted in 15-20 second segments and mixed it around in between each segment. This will prevent burning the chocolate. After you have done this the chocolates should be melted and runny.
Step 4: Dipping the Pretzels
Put the pretzel in the chocolate bowl and mix around until thoroughly coated. Then use the knife to get it out and put it on some tin foil to harden.
Step 5: Set to Harden
Put the pretzels in the fridge for an hour. After an hour they will be completely hardened. I also tried doing the same things with almonds. You can sprinkle coconut flakes or even sprinkles on it to give it more flavor.
