Introduction: Chocolate Raspberry Dome
In this instructable I will show you how to make this delicious dome dessert. It is a very elegant looking dessert which uses the iconic pair of chocolate and raspberries. This dessert is just about as indulgent as desserts can get.
Step 1: Ingredients and Equipment
Raspberry Jelly
- 120g frozen raspberries
- 3 sheets gelatine
- 1tbs sugar
- 1 cup cold water
Chocolate Mousse
- 300ml heavy cream
- 200g chocolate
- 50g butter
Raspberry Sauce
- 1/4 cup Raspberry juice(from the frozen raspberries)
- 1tsp corn starch(cornflour)
- 1tsp water
Chocolate Ganache
- 100g chocolate
- 50ml heavy cream
Note: Plus extra chocolate for the decoration and oil spray
Equipment
- Whisk
- Spatula
- Small pot
- Microwave safe bowl
- Baking paper
- Hemisphere mold
- Small bowl
- Container
- Squeeze bottle
- Wire rack
Step 2: The Raspberry Jelly
- Blend the frozen raspberries in a blender, this is the raspberry puree
- Put the gelatine in a small bowl with the water and let it soften for 5-7 minutes
- Put 1/3 of the raspberry puree in a small pot and warm up with the sugar, add the gelatine slowly to dissolved mix in the remaining puree
- Cover a small tin/container with cling wrap, place the mix inside, freeze for 1 hour (until set)
Step 3: Chocolate Mousse
- Put the chocolate and the butter in a small microwave safe jug/bowl
- Microwave for 30 seconds at a time mixing between intervals
- When melted leave to cool for 10-15 minutes (or until warm to touch)
- Beat the heavy cream in a separate bowl when the chocolate mix has cooled fold in 1/3 of the cream
- Slowly fold the chocolate mix into the rest of the cream
Step 4: Preperation
- Get the jelly out of the freezer and cut out using a small circular cookie cutter
- Grease a the mold and then fill 3/4 of the way with the chocolate mousse
- Gently push the jelly circle slightly and cover with chocolate mousse until level to the mold edge (make sure that the jelly is not visible)
- Tap/shake on the bench a few times to get the mousse to settle
- Using a bench scraper (or the edge of a knife) scrape the excess mousse off to create a smooth level top
- Place in freezer until hardened (2-3 hours)
Step 5: Decorations
Raspberry Sauce
- Place the raspberry juice in a small pot on medium-low heat
- Mix the corn starch and water and mix into the juice heat until slightly thickened
- Leave aside to cool until needed
Ganache
- In a microwave safe bowl heat up the chocolate and cream in 30second intervals until melted
Chocolate decoration
- Melt 50g of chocolate and put into a small ziplock bag cut of a small tip and scribble a few designs onto a sheet of baking paper. Leave to set
Biscuit crumb
- Crush 1 biscuit per dome you are making
Step 6: Assembly
- Once the mousse has set take it out of the freezer, take one dome out at a time and place on a wire rack with a sheet of baking paper underneath
- Coat the dome with ganache and tap down slightly to evenly spread (use a spoon if needed)
- Place the coated dome on a plate surround the dome with the crushed biscuits
- Place the raspberry sauce in a squeeze bottle and squeeze little dots out
- To finish it off push the chocolate decorations into the top
