Introduction: Christmas Rail Car 8
A rotating angel inside an open ball is rail car number eight in what (I hope) will be a series of ten, one published every two weeks until Christmas. This O gauge car (wheels, axle, coupler and bed are all 3D printed plastic) is part of an active train.
Step 1:
Start by converting a servo motor to a battery powered gear motor. Remove the four screws from the bottom of the motor.
Step 2:
Remove the stop on the gear.
Step 3:
Remove solder from the two tabs that attach to the motor.
Step 4:
Remove the electronic board, then remove the screw.
Step 5:
Remove pot from motor.
Step 6:
Solder wires to motor, then replace back and assemble with 4 screws.
Step 7:
Using a 3d printer, print the various parts. Print the ball at 120% size and cancel when it is 70% complete. Print the angel at 65% size.
Assemble the rail carrier and wheels.
Step 8:
Add the rail bed.
Step 9:
Add the bed caps.
Step 10:
Insert the servo motor, then solder the leads from a battery carrier (2 AA) to the motor leads.
Step 11:
Glue the angel to the servo horn.
Step 12:
Attach the battery case with velcro tape.
Step 13:
Glue the ball to the servo base, place on a track and let it ride!
