Introduction: Christmas Tree Water Level Indicator
I built this thing real quick last night so my dad could check the water level without having to crawl underneath the tree. After a handful of requests for parts lists/code on Reddit, I decided the best way to share said information was in the form of an Instructable, so here we are! This instructable was done with the same haste and disregard for quality as the project itself, so I'm sure there will be mistakes.
I will add some more pictures to this Instructable later this week.
Some Future Plans for This Build:
-Possible addition of automatic watering system. Solenoid valve with a gravity fed system is the most likely option.
-Might upgrade to a better and larger depth sensor.
Step 1: Parts List:
(1) Depth Sensor (pictured above)
-This is the sensor I had lying around from a starter kit.
-Over on the original Reddit thread, u/marky-b sent me a link to this awesome sensor. It pricier than the one I used at $30, but it's length is much better suited for the application.
(3) LED lights (second picture above)
-Make sure they are all a different color to indicate different water levels. I used blue, yellow, and red.
(1) Mini Straight Wire Butt Connector (third picture above)
-Or whatever method of connecting the 3 LED ground pins to the resistor. Just as long as the connection is solid and provides adequate separation form the positive terminals.
(1) Arduino Nano
-Any board works fine, but the small size of the Nano is nice for this simple project.
(1) 1kOhm Resistor
(7) Jumper Wires
-Female to Female if you are using a Nano like I did
-Male to female for Arduino Uno or Mega
(1) Power Supply
-I just used the micro USB port in the Nano and plugged it into the wall with a USB adapter.
(1) Electric Tape
-For wrapping up exposed wire ends, or substituting the wire connector.
(1) Whatever Box you can find to waterproof the Arduino
-Because somebody is eventually going to spill water everywhere trying to water the tree.
Step 2: Wiring Schematic
Step 3: Code
I put instructions for calibrating your water sensor in the sketch before I decided to make an Instructable.
<p>//-----------Christmas Tree Water Level Sensor Sloppy Code and Tutorial---------//<br>/* Brief Foreword: I originally copied the code for the serial output of the sensor from an elegoo example sketch, and added the if/else stack to trigger the LEDS. After a couple of requests to post the code, I went through and cleaned up/commented throughout the sketch. tl;dr Half of this sketch is originally from Elegoo's example program. </p><p> This code/program works with any arduino or clone you have. I used an arduinoNano for mine, but you can use an Uno or Mega if thats what you have. Just make sure you switch the 'LED const int' values to the appropriate pins you're using. </p><p> I slapped this device together very quickly, and spent very little time testing the water level values. I cannot guarentee that your depth sensor will yeild the same values at the same depths as mine. To address this, I wrote a sloppy callibration instructable below. </p><p> --------**********CALLIBRATION/SET UP INSTRUCTIONS********---------------------------- [1]- WITHOUT EDITING any of this sketch, upload sketch to your arduino and open serial monitor. [2]- Insert depth sensor into water to a depth that you would consider the minimum amount needed to trigger the blue LED (full indicator). Write down this value and note it as 'full'. [3]- Repeat step 2 to determine the value you will assign to the 'low' value. Anything above this value but below the 'full' value will trigger the yellow LED. Any value below this value will trigger the red LED. [4]- Plug the values determined from steps 2 and 3 into the const int's 'full' and 'low' below. [5]- Upload sketch again with updated values, and you're done! */</p><p>const int full = 200; const int low = 50;</p><p>int depthSensor = 0; //set depthsensor L pin to Analog 0. You can set to any analog pin you want. int lastValue = 0; char printBuffer[128];</p><p>// The following is setting the LED pins to the corresponding digital pins. You can set these to any digital pin you want. const int blueLED= 2; const int yellowLED= 3; const int redLED= 4;</p><p>//-------After setting your water level and pin assignments above, ideally you should't have to change any of the code below. void setup() { //Begin communication with serial port. This is used to set test your depth sensor and determine which values you want to assign to your full/low/empty values. Serial.begin(9600);</p><p> //Set LED pins to OUTPUT pinMode(blueLED, OUTPUT); pinMode(yellowLED, OUTPUT); pinMode(redLED, OUTPUT); }</p><p>void loop() { // get sensor value: int value = analogRead(depthSensor); </p><p> //If the change from last value to current value is greater than 10, display the current value. if(((lastValue>=value) && ((lastValue - value) > 10)) || ((lastValue 10))) { //Displays depth sensor value to serial port. sprintf(printBuffer,"ADC%d level is %d\n",depthSensor, value); Serial.print(printBuffer); Serial.println(); Serial.println(value); Serial.println(); lastValue = value; // sets last value to current value for next loop. } if(value>=200) { digitalWrite(blueLED, HIGH); digitalWrite(yellowLED, LOW); digitalWrite(redLED, LOW); } else if((value <200)&& (value>=50)) { digitalWrite(blueLED, LOW); digitalWrite(yellowLED, HIGH); digitalWrite(redLED, LOW); } else { digitalWrite(blueLED, LOW); digitalWrite(yellowLED, LOW); digitalWrite(redLED, HIGH); } delay(250); }
Step 4: Calibrate
I cannot guarantee that your depth sensor will read the same values at the same depths as mine. To address this, I put some set up instructions in the sketch that I will also post here.
At this point you should have:
- Your depth sensor connected to the appropriate ports on your Arduino board of choice
- Your Arduino board connected to your computer
- A glass of water nearby for testing.
[1]- WITHOUT EDITING any of the sketch, upload the original unedited sketch to your Arduino and open serial monitor.
[2]- Insert depth sensor into water to a depth that you would consider the minimum amount needed to trigger the blue LED (full indicator). Make note of what value this registers as in the serial monitor. For now we'll refer to this value as 'full'.
[3]- Repeat step 2 to determine the value you will assign to the 'low' value. Anything above this value, but below the 'full' value will trigger the yellow LED. Any value below this value will trigger the red LED. For now this will be referred to as 'low'.
[4]- The first 2 variable declarations you see in the sketch are:
const int low = 50;
You want to replace '200' with your 'full' value, and replace '50' with your 'low' value.
Resulting code should look like this:
const int full = 'full';
const int low = 'low';
Obviously with 'full' and 'low' being replaced by the actual integer values you got.
Other than that, you do not need to change any other values in the sketch. Unless you are using the pins in the original sketch for any additional sensors or displays, in which case I doubt you need me to walk you through the configuration.
Step 5: DONE!
Now go set that thing up so your dad/grandfather can ignore it anyway and crawl under the tree to physically check the water level because he hasn't trusted technology since Terminator 2 came out.
