Introduction: City Street Racer
Here are step by step instructions on how to build your own street city racer game.
4 double A batteries
battery box
tape
a motor
scissors
push switch
box
TP tube
pencil
paper
colored pencils or markers
OR the electric pencil sharpener eureka crate
Step 1: Step 1: Motor and Batteries and Switch
First you need a motor and batteries. Specificly the battery pack in the photo in the photo. You can get the motor and battery pack from the "electric pencil sharpener Eureka Crate." Then you need the switch which you can also get in the "electric pencil sharpener Eureka Crate." Then you need to connect the wires by color.
Step 2: Step 2: the Base
Next build the base you will need a small rectangular cardboard box and scissors. Cut out a large rectangle on the top of the box.
Step 3: Step 3: Build the Game.
For this next step you are going to take an empty toilet paper tube and attach it to the motor. Now draw out the street and add some cars. Give them color so you can see them easier You can add as many as you like. The more you add the harder it is to avoid them.
Step 4: Step 4: Put It All Together
Once you finish everything you have to tape the motor with the game piece on it on the inside of the box right on the wall. Now make a hole in the side of the box and stick the switch through so you can see the lever on the outside of the box. Add a start sign to the switch. If you want you can add a container so you can have people pay to play. Now take a pencil or a dowel and tape a ting paper car to it and this is what will avoid the cars.
Step 5: Step 5: Testing the Game
After you are finished it is time to test it turn it on using the switch on the battery pack. Hold the switch with the start sign to begin. Move your pencil side to side and avoid the cars. It will only go one speed so you know.
