Introduction: Clash of Clans - Wizard - Mask
Materials:
Fab Foam Sheets (Quantity, colour and size)
1 - Tan / Beige 300mm x 450mm
1 - White 300mm x 450mm
1 - Blue 300mm x 450mm
1 - Brown 225mm x 300mm
1 - Yellow 225mm x 300mm
1 - Black 225mm x 300mm
Scissors
Ruler
Pen or pencil
Elastic
Stapler
Double sided sticky tape
12mm x 33mtrs roll
Dart or equivalent (for poking a hole through two pieces of polystyrene).
2 Polystyrene blocks
25mm wide x 25mm depth x 60mm high
PC or MAC with an A3 or A4 printer
Using the .pdf template provided download, draw and cut out each part matching the colours.
Before we go any further we will need to cut eye holes out so grab your ruler go to the mirror and measure from the centre of one eye across to the center of the other and mark out on the tan/beige skin tone fab foam sheet and cut.
Grab the polystyrene blocks pop a hole in the centre of each using the dart so that you can pass through the elastic, pass the elastic through both pieces of polystyrene tie a knot at either end. Take the tan/beige skin tone fab foam sheet face down position the elastic and staple at each end of the elastic and slide each polystyrene block to either side.
Starting with the hair working down the face stick all the cut pieces of foam together.
Keep an eye out for more clash of clans character masks
Thank you for viewing.
PS please let me know how you got on making this mask
Best regards
blanthegenius
Scissors
Ruler
Pen or pencil
Elastic
Stapler
12mm x 33mtrs roll
Best regards
blanthegenius
