Introduction: Clay 3D Print
My first experience with clay 3D printing.
Software: SKCam. Hardware: 3D Potter. Material: NARA Modeling clay.
Step 1: Tool Path Generation
Using the radial symmetry tool in SKCam, I defined nine axes and drew a simple shape. I used the repeat tool, with a small degree of rotation and a slight scale down to create the first fifteen layers. I then, from the 15th layer, scaled back up and rotated in reverse back to the original size and position. I exported the g-code file for the 3D Mini Potter.
Step 2: Preparation and Printing
With help, I mounted the prepared tube of NARA to the 3D Potter Clay 3D Printer, and loaded the g-code file to the web app. After zeroing the nozzle, I began the print. The print had trouble adhering to the bed at first, but with some manual manipulation, I was able to get the material to stack correctly after the second layer. I observed the print throughout the process, to make sure there were no deformations. After it was done, I used to a scalpel tool to remove visible irregularities from the bottom layer.
Step 3: Continued Work
I'll continue to fire and glaze the piece. Next time, I'll make the rotation effect between layers more obvious.
