Introduction: Cleaning Sea Glass With Denture Tablets (and Jewelry, Water Bottles, Craft Materials, Glass, Carboys, Toilets, Etc.)
Step 1: Soak
Step 2: Rinse and Dry
Rinse the pieces and them let dry on a towel.
* Do not worry, this process will not remove the cloudiness from real seal glass
Step 3: More Ways to Clean With Denture Tablets
Other Cleaning Uses
Clean a coffeemaker or a stained cup: Run your coffeemaker with a couple denture tablets in the tank to get rid of hard water or coffee stains.
Water Bottles: Aluminum & Plastic Water Bottle manufacturers make their own cleaning kits that are actually nothing more than denture cleaning tablets, but with a higher price.
Retainer Care: This is the best way to clean a retainer without causing wear from repeated brushing. I soak mine for 10 minutes every week.
Clean your jewelry: Clean metal and beaded jewelry by soaking them for just a few minutes. It will also return the sparkle to a faded diamond.
Clean glass wear: To get rid of the mineral deposits on glass just fill with water and drop in a tablet for a few minutes. Use the same method to clean thermos bottles, cruets, glasses, and coffee decanters.
Cleaning beer brewing equipment: Cleans the yeast out of carboys (see here)
Clean your toilet: Drop in a denture tablet and then flush 20 minutes later.
Clean enamel cookware: FIll a dirty or stained pan with warm water and drop in a tablet. Come back later and your pan will be much easier to clean.
Unclog a drain: For a slow drain drop a couple tablets into the drain and run the hot water. For a clog, put 3 tablets and 1 cup of vinegar down the drain and wait 5 minutes before running hot water.
