Introduction: Clear Cover FOR YOUR MP3 PLAYER!!!
Are you always scratching the screen on your mp3 player.While now there's an easy and cheap way to keep it protected.
Step 1:
I'm a person who scratches their screen on accident many times.I found a way to protect your screen using a plastic water bottle.Maybe this cover can help you as much as it has helped me.
Supplies needed:
one water bottle
hack saw
knife
scissors
metal pan
tin foil
mp3 player(does not matter what kind)
hammer
tacks or short nails
piece of wood or cardboard
Supplies needed:
one water bottle
hack saw
knife
scissors
metal pan
tin foil
hammer
Step 2:
The first step is to find or cut a piece of wood(or cardboard)that is the size of your mp3 player.Make sure it's the right thickness too or it won't come out right.
Step 3:
Next you need to cut your bottle big so you can fold the sides of the bottle around the piece of wood you cut.After folding the sides you need to use your tacks(or nails)and hammer to hold the plastic to the wood.Because the plastic will shrink and if it is not held to the wood the plastic will bend in all directions.
Step 4:
Then when your done tacking the plastic to your wood you need to pre-heat the oven to 550 degrees.While the oven is pre-heating you need to get a metal pan and a piece of tin foil to put on your pan.next you need to put your wood and cover on the pan standing up.It should only take 3 to 5 minutes to be done ,but you need to keep an eye on it because it could fall over.
Step 5:
When it done just take it out and let it cool for a couple of minutes.After it's done cooling down just take the tacks out and put on your mp3 player.
Step 6:
Don't worry about it if you mess up just figure now you have targets.
