Introduction: Clip on Pencil Sharpener
First, get the measurements of the trashcan using the ruler that you want to use the pencil sharpener on.
Second, write the measurements down onto a paper and create a sketch of it listing the Length Width and height, and thickness of the top part of the trashcan so you can find the right size for the pencil sharpener to clip onto.
Third, go into tinker cad and create a 3d model of the trashcan using the measurements you got.
Fourth, create the base that clips on the trashcan using the thickness of the trashcan of the top part and see if it fits well onto the 3d model of the trashcan.
Fifth, get measurements of the pencil sharpener your using and write them down and create a sketch of it.
Sixth, create another base ontop of the main base that's big enough to fit your pencil sharpener inside it.
Seventh, make a hole that's big enough to fit the pencil sharpener inside of it and create another hole on the bottom that's slanted so the pencil shavings can slide down easier and fall into the trashcan.
Eighth, align them where they are even and then group them.
  • Computer/Chromebook
  • Ruler
  • TinkerCAD
  • 3d Printer
Step 1: Measurements
Step 2: Notes and Sketch
Second, write the measurements down onto paper and create a sketch of it listing the Length Width and height, and thickness of the top part of the trashcan so you can find the right size for the pencil sharpener to clip onto.
Step 3: Create 3d Model
Step 4: Create Base That's Going to Clip on Trashcan.
Step 5: Base for the Pencil Sharpener
Fifth, get measurements of the pencil sharpener your using and write them down and create a sketch of the pencil sharpener then create another base on top of the main base that's big enough to fit your pencil sharpener inside it then make a hole that's big enough to fit the pencil sharpener inside of it and create another hole on the bottom that's slanted so the pencil shavings can slide down easier and fall into the trashcan.
Step 6:
Sixth, use the align tool and align them together then group them together and delete the model of the trashcan after you make your final design.
Step 7: Step 7 Go Onto MakerBot Print
Seventh download your project off of tinker cad as an stl. Then download MakerBot Print, after its downloaded go into the app and when it loads in the top left corner there is a files icon and you want to click that then click add models and find your 3d model and import it.
Step 8: Step 8 Edit Model
Eighth you want to go to the right of your screen and click the settings icon then click support type and add breakaway support. After you do this go to the bottom left and select the printer you will be using. Download your model onto a ThumbDrive and import it into your 3d printer and start your print!.
Step 9: Final Model
After you are done printing it should look something like this it might be different depending on the size of the trashcan.
