Introduction: Coconut Zipper Gift Box
Coconut Zipper is made of real coconut with zipper. You just have to remove the coconut water and meat, stick zipper in the middle of coconut shell.
It is great gift box for eco-friendly products, jewelry, chocolates or you can also use it for keeping chess pieces, dice etc.,
I am using it as jewelry case ;) See! How cool it is!
Step 1: Supplies
Things you will need for making coconut zipper is
Coconut
Zipper - Longer one (that should fits coconut circumference)
Hot glue.gun
Glue sticks
Nail
Hammer/Iron rod
Spoon/knife
Sand paper
Thread and needle
Scissor
Bowl for collecting coconut water
Step 2: Drain Coconut Water and Drink It :)
Take coconut, nail , hammer/iron rod and bowl.
Place the nail over one of three black eyes. Hammer the nail to make a hole.
Drain the coconut water completely in bowl. Filter and drink it.
(Coconut water has lot of benefits. It boosts hydration, reduces blood pressure and removes acne)
Step 3: Break It Into Two Even Piece!
It is tricky part, because you should break it evenly in the middle. Here, I used iron rod to break it. Just hit the coconut (in the middle) few times with iron rod. It will break into two piece easily. It is time consuming method, but have to do it very carefully.
Other option for perfect cut:
Mark the coconut in the middle and cut it using hack saw. (If I have hack saw, I will follow this method only)
Step 4: Remove Coconut Meat and Eat It!
Microwave each coconut for couple of minutes. It will be really very hot. Use oven mitton to take out from microwave.
Let them cool for sometime.
Now use spoon/knife to take out the meat. Insert spoon inbetween the coconut shell and meat, and twist & rotate the spoon little by little. For me, its worked on first try itself.
(Since its microwaved, the edges of the coconut meat gets loosen, hence It will come off easily)
You can use the coconut meat for making dip/chutney/butter or you can have it raw.. I love to eat it raw :)
Step 5: Sand Out!
Sand out the coconut shell and rim, until it feels smooth texture.
Step 6: Zipper Time!
Measure the coconut shell circumference with zipper and cut zipper according to the measurement.
Stitch both ends with thread and needle inorder to secure the zipper head.
Step 7: Glue It!
Take one half of coconut shell , stick the zipper inside of it using hot glue. Leave some space for zipper head to open the zip. (Make sure that zipper right side facing out)
Once u glued it on one side. Take other half of coconut shell, unzip the zipper and start applying glue on inner side of shell and stick the zipper.
TADA! its done... Surprise your loved one with gift as well as beautiful GIFT BOX :)
