Introduction: Coffee Table
Hey everyone!
I wanted a small coffee table to be in my living room So i went a head and built one!
Enjoy !
Step 1: Mix Cement and Sand in a Box
Take two cement packs and half a kilo of sand and mix it together with water
Step 2: Create the Pole
I have bought 4 poles ( was long one but i cut it )
Made sure it`s the same height, and attached them all to some bas ei build ( from wood )
Step 3: Drown It !
Once you finished mixing the mixture of sand , water , and cement
" Drown " the base of the legs and make sure it sitting good
Step 4: Check With Leveler
Make sure it`s the same height
Let it dry for 12 hours and then poor 1/2 a liter of water to the cement - it will obserb in it - that way the cement will be stronger
Step 5: After Two Days
Seems good
Step 6: Remove the Plastic Box
Slowly remove the plastic box from the table
Clean the sides and remove leftovers
Step 7: Paint the Legs
Choose some random color, and paint the legs
Use a duck tape to mark the exact place fo
Step 8: Remove the Duck Tape
Step 9: Paint It!
i painted it , 3 layers
Let it dry between one layer and the other
Step 10: Padding
Add beneath the legs some padding , for it to move easy
Step 11: Done!
It was a fun quick project!
Let me know what you think
