Introduction: College Bed Loft (Twin XL)
How to make a loft for a dorm, or any other tight space!
Dimensions given will accommodate an Extra-Long Twin mattress with 1' extra on every side.
We are making these lofts to take to Iowa State while living in a Dorm. We will be able to put a desk or sofa underneath. A loft is a great way to gain floor space; so much more room for activities!
EDIT:
After a full school year of sleeping on this loft I have made many drastic improvements, mainly that it now accepts the frame provided by the school. This new version can be found here. Thanks all for your support!
EDIT:
Step 1: Materials
My roommate and I built both lofts at once, so keep that in mind in the pictures; also, he weighs in around 250 lbs, so we upgraded the "slats" on his from 2x4's to 2x6's.
These lofts are made entirely of dimensional lumber, bolts, and screws.
Tools:
Miter Saw (power)
Cordless Drill with Screw bit
Corded Drill (opt.) with 3/8" drill bit
Hardware:
18 3/8" Carriage Bolts
18 3/8" Flat Washers
18 3/8" Lock Washers
18 3/8" Nuts
Small box of 2-1/2" Deck Screws (torx opt.)
Lumber:
8 - 2x4x6'
8 - 2x4x8'
3 - 2x6x8'
Tools:
Miter Saw (power)
Hardware:
18 3/8" Nuts
Lumber:
8 - 2x4x6'
8 - 2x4x8'
3 - 2x6x8'
Step 2: Cut Your Wood!
2x4
8 @ 72" uprights (6')
1 @ 88" back bottom brace
2 @ 78" inside slat rest
4 @ 44" ladder/ side brace
6 @ 44" Slats (can replace with 2x6)
2x6
2 @ 88" main horizontal support
2 @ 44" top end braces
**** edit****
these dimensions are about 8 inches too long and 4 inches too wide
I would also recommend like a flat piece of plywood in the corners to stabilize
2x6
**** edit****
Step 3: Assemble Uprights
Fasten two 2x4's at a right angle with deck screws.
Step 4: Assemble Main Beams
Fasten the slat rest to the "main horizontal support" using three bolts. Feel free to pin these two boards together with screws while drilling.
Step 5: Uprights + Main Horozantal Support
Fasten the main horozantal support to the uprights (legs) using two bolts.
Step 6: Front + Back
join the front and the back using one bolt on the 2x6
Step 7: Add Bottom Bracing
Move the legs to reach the boards, this will square up the legs.
Fasten with screws.
Fasten with screws.
Step 8: Paint It?
Paint it IOWA STATE UNIVERSITY colors! Go Clones!
Step 9: After Thoughts
We're all moved in but ran into some snags along the way; the main one being that the matteresses are much smaller than expected. For the dorm mattress i was provided, the loft is 8 inches too long and about 6 inches too wide. Luckily, we brought a hand saw because we had to cut 8" off to fit one on the wall with the door.
These lofts were very stable on their own, but we brought these braces anyway, so i put them to use
Another thing we did is get automotive cup holders from walmort, and they fit perfect; great for holding beverage, or put an empty cup in it and hold your cell phone, ipod, or keys.
