Introduction: Complete Stencil Tutorial Using a Free Program
A tutorial on making a stencil with an open source program called the GIMP.
I looked on all the Instructs tagged with stencil, and not one gives a step by step for making a stencil in my favorite open source photo program The GIMP.
Step 1: Materials and GIMP
-What You Need-
-printer
-craft knife
-The GIMP
-surface to cut on (self healing mat)
-spray mount (optional)
-spray paint
GIMP is an open source raster based graphics editor. It was designed to replace Photoshop.
You can get it here. gimp.org
Install it, open it up, and familarize yourself with the interface for a bit. Done? Good. Isn't open source great? Didn't cost a dime!
-printer
-craft knife
-The GIMP
-spray paint
Step 2: Pick an Image and Open Your Picture in GIMP
Pick a good simple image (remember: simple equals less cuts) preferably on a white background. This can be hacked by simply erasing around an image in MSPaint or what have you.
I chose a tasteful Stormtrooper sculpture to stencil. Nerdtastic!
Step 3: Crop It
Crop out the parts you want to make a stencil of with the Crop/Resize Tool (Tools>Transform Tools>Crop).
a. GIMP allows you to save a copy in case you want to use the uncropped-unedited image later. Save the copy, then go open the copy in GIMP. (File>Save A Copy)
Step 4: Simplifying the Image
We need to simplify the image now. We will do this by Colorify-ing the image. There are two ways of doing this in GIMP.
a.One way is to go to (Tools>Color Tools>Colorize). If you use this method, you will want to set the Hue and Saturation to 0, and adjust the lightness to fit the image (this can be done to taste, generally you want about an even light to dark for a stencil.)
b. The other (and redundant) method is to go to Filters>Colors>Colorify, and select your color (you'll be selecting white).
Both methods are pictured, I chose to use the filter.
Step 5: Tweaking the Contrast and Brightness
Now I'm going to tweak the contrast and brightness a bit. (Tools>Color Tools>Brightness-Contrast) I'm trying to get a hard line on the helmet, the hardest part on this image to keep intact.
Step 6: The Threshold Tool
Next I use the Threshold tool (Tools>Color Tools>Threshold) You'll want to play with the settings to get good hard black and white , which is perfect for stenciling.
Step 7: Stencilable Image
There you go! You end up with a semi usable image.
The key to stenciling is to editing out the "islands" of white in your image. You can make little bridges for them if need be. Once again this can be accomplshed in whatever bitmap editing program (MSPaint) you have lying around. I think the image I have can be edited by hand, so I'm going to print it now.
Step 8: Get Ready to Cut
Get your craft knife(s) and you image and get it all ready for slicing and dicing.
Step 9: Outline Your Cuts (optional)
If you have a fairly low res image, this is a good idea. Silver sharpie.
Step 10: Cut and Spray
Once your done cutting, it's time to spray. A simple one layer will do (you could make a 1.5 layer but that's a different tutorial)
As for spraying.
A guide to cutting stencils
• Think from outside the box.
• Collapse the box and take a fucking sharp knife to it.
• Leave the house before you find something worth staying in for.
• It's easier to get forgiveness than permission.
• Spray the paint sparingly onto the stencil from a distance of 8 inches.
• Be aware that going on a major mission totally drunk out of your head will result in some truly spectacular artwork and at least one night in the cells.
-Banksy
Have fun!
As for spraying.
-Banksy
Have fun!
