Introduction: Completely Crispy Crunchy Cheesy Cheezlings
If you want a quick cheesy, crispy and crunchy snack....there isn't anything better than a pack CHEEZLINGS. Cheez-it as it is known in some parts of the world,the others know them as Cheezlings- make a delicious snack.
And if you can make the same at home with no effort and in very little time,it is not wonderful?
Step 1: Ingredients
You will need:
All purpose flour 1Cup
grated parmesan cheese 1 Cup
butter cubed and cold 1/2 cup
1/2 tsp garlic powder
1/2 tsp salt
fresh cracked pepper by taste-1/4 tsp.
maybe 1tspn cold milk.
Step 2: Dough
Put all the ingredients in a mixing bowl.
work the butter into the flour till it forms a tough dough.
In case the dough is too hard add 1/4tsp cold milk.(too much of liquid will make the cheezlings soft).
knead the dough well and then wrap in a cling foil and allow to rest in the fridge for around 15 minutes.
Step 3: Forming
Roll out the dough into a sheet of around 0.5 cm thickness.
With a pastry cutter cut into the sheet ,parallel horizontal lines -about 2cm apart.
Then cut vertical lines at the same distance to give squares.
At the center of each square mark a circle with a straw (This step can be completely omitted , it is only for decorative purposes.)
Lift each square and place on a baking tray.
Step 4:
preheat the oven to 200C.
Bake for around 8-10 minutes or till the crust turns golden brown.
Remove from the oven and allow it to completely cool.
VOILA!!!! the perfect
CRISPY;
CRUNCHY
CHEESY
CHEEZLINGS are ready.
