Control Home Appliances Using Esp32 Bluetooth
47920
Intro: Control Home Appliances Using Esp32 Bluetooth
Hi!! Welcome , Today we will make a project to control Home Appliances running on mains AC supply, using esp32 and an Android Application to connect with.
STEP 1: Step1: Circuit Diagram
The Circuit Diagram is very simple just connect the IO pins like this:
Relay Signal pins:
1 --->IO15
2 --->IO2
3 --->IO13
4 --->IO12
If u want to control more devices (even though diagram shows only 4 relays)
here are the pins
5 --->IO16
6 --->IO17
7 --->IO5
8 --->IO18
STEP 2: Step2:Coding
Now just connect your ESP32 and upload the code using Arduino
Code is there for Download !!! Just upload it to esp32
STEP 3: Sterp3: Testing
First turn ON Bluetooth and pair the esp32 with name "Rhee ControlSmart101" and then DOWNLOAD the app using the link from google PlayStore
Link: https://play.google.com/store/apps/details?id=com....
click on search button Choose the device and press connect button
Now try switching on and off device3 if Led on esp32 lights up (may vary on some esp32) it means its working and so should other pins work
And Now u have made your own System to Control AC mains Appliances
