Introduction: Cook Your Food With a Glue Gun
In this Instructable you will learn how to Turn a Regular 1$ Glue Gun into a Mini-Electric Stove. Its very simple to do and very helpful if you're ever in need of a stove.
Check Out The Instructional Video Here!!!
Step 1: Materials
You will Need the following-
$1 Glue Gun
2 Paper Clips
1 Can of Food
*Optional - TinFoil
Vide0------>http://www.videojug.com/film/turn-a-glue-gun-into-a-mini-electric-stove
$1 Glue Gun
2 Paper Clips
1 Can of Food
*Optional - TinFoil
Step 2: Make Stove
Step 1- Unscrew the Glue Gun and Open it,
Step 2- Remove everything from the inside, like the Trigger and the Nozzle.
Step 3- Locate the Heat Generator which is on the Nozzle and Save it.
Step 4- Straighten your 2 paper clips, then wrap them around the Heat Generator,
(Make sure cord is not plugged in) Refer to the Picture below to see how it should look like.
Like a spider Shape.
*Make sure the Paper clips are tightly wrapped around the Heat Generator.
Video------>http://www.videojug.com/film/turn-a-glue-gun-into-a-mini-electric-stove
Step 3: Cook Food and Enjoy
Now open your can of Soup/Pasta and Place it on top of your Stove
*Make sure the legs of the stove are stable, if not trim some of it off.
Plug the Cord in the outlet and let it sit for 5 to 10 minutes (depending on the size of can)
Check on it from time to time once its the right temperature, remove it and EJOY!!!!
Refer to the Instructional video for a better idea of how to do this project.
Check out the video-----> http://www.videojug.com/film/turn-a-glue-gun-into-a-mini-electric-stove
.......................Nextraker
