Introduction: Copy an USB Drive With a Shortcut Key
This is a simple DOS batch program which allows u to copy all data of any USB drive to ur hard drive, when a drive is connected to ur PC.
Make sure u have administrator privileges.
Step 1: CODE WRITING
Copy paste the below code to ur notepad
@echo off
if exist c:\pendrvcped\ goto :cop
md c:\pendrvcped
:cop
echo *****Antivirus scanning your drive for Viruses*******
echo *****DO NOT INTERRUPT IN THE MIDDLE********
xcopy /a /e /k /q /h <ur drive to be copied eg.E>: c:\pendrvcped
cls
echo *******Virus scan completed sucessfully****
echo.
echo ******NO VIRUSES FOUND********
pause
Just type the one word drive letter in the angle bracket Eg. E:
Save the notepad file as drvcpy.bat in desktop
@echo off
md c:\pendrvcped
:cop
cls
echo.
pause
Step 2: Shortcut Assigning
Create a shortcut on the desktop for drvcpy.bat
Now right click shortcut goto properties and choose ur shortcut key. Check pic
Step 3: Sample
You are ready to go now
Check out the Sample
After u press the shortcut key the cursor blinks which means the files are being copied.
The time u can tell others that u are scanning the drive for viruses.
Step 4: MODIFIED CODE
If u r copying more than one drive, u can create a separate random named folder with date and time of that copy with the below code
@echo off
md c:\pendrvcped
:cop
set nary=%random%
set kd=%date%
set kt=%time%
md c:\pendrvcped\%nary%
echo %kd% >> c:\pendrvcped\%nary%\$$$$KDT$$$$.txt
echo %kt% >> c:\pendrvcped\%nary%\$$$$KDT$$$$.txt
xcopy /a /e /k /q /h f: c:\pendrvcped\%nary%
cls
echo.
pause
u can see the date and time in the file $$$$KDT$$$$.txt under the random named folder post copying.
@echo off
md c:\pendrvcped
:cop
set nary=%random%
set kd=%date%
set kt=%time%
cls
echo.
pause
Step 5: Automation and More
More....................
1. U can also automate this complete code soon after an USB drive is connected w/o any shortcut key
2. Drive chooser
3. Hidden pendrvcped folder + more attributes
4. Totally running in hidden mode
5. Use the program even u r as guest.
mail me at kua201@gmail.com
2. Drive chooser
