Introduction: Coraline's Dragonfly Clip
About: I like making little treats and pretty much doing anything crafty. I want to learn new techniques and share how I do what I do. Edit - I took a break for awhile but I'm ready to get back into sharing my work …
Follow this instructable to make your very own dragon fly hair clip as seen on Coraline!
This clip is a great accessory for a Coraline cosplay and would hold up to light use. The materials could be altered to create a studier clip but the one here would cost about $8.00.
Step 1: Supplies
To make this clip (approx. 2" wide , 1 1/2" tall) you will need:
Yellow craft foam sheet,
Gold non-toxic craft paint
Blue non-toxic craft paint
Pink and blue self adhesive rhinestones of various sizes
Pen
Scissors
Paintbrush
Cardstock
Metal alligator hair clip
Hot glue
Template
Step 2:
Trace your template onto the yellow foam sheet and cut out dragon fly.
Paint with several coats of gold paint and let dry between coats.
Paint cardstock blue.
Let dry.
Step 3: Bling
Add blue rhinestones down the middle of the dragonfly. Start with one big one and progressively get smaller as you go down the back.
Add pink rhinestones on the wings. Try to keep the layout of the stones symmetrical if possible.
Press each stone down once you place it.
Step 4: Backing
Trace your dragonfly on to the wrong side of the blue painted cardstock. Cut out and slightly trim the edges a little more so they don't stick out from the dragonfly top once assembled.
Hot glue the wrong side of the top dragonfly to the wrong side of the cardstock and press firmly.
Hot glue the alligator hair clip long ways across the underside of the dragonfly.
Step 5: Wear
Your clip is now ready to wear!
Store your clip in a safe place when not in use.
