Introduction: Crispy Pork Dumplings (From Scratch!)
Have you ever found yourself craving dumplings? Juicy, porky delicious dumplings? But, somehow, sadly, you are dumpling-less. Maybe the shops aren't open, or you can't get delivery, or maybe no place near you makes good dumplings. Well, there's no need to get down in the 'dumps'! In a few hours you could be eating delicious crispy pork dumplings- made by yourself! And if you make them yourself, then no will know how many dumplings you eat- so you can have as many as you like without judgement!
Here's my recipe (I'm half Asian, so you know this is Legit. I KNOW my dumplings.) for delicious and crispy pork dumplings with an easy homemade skin and savoury pork filling with garlic and spring onions. This recipe takes a little while but it is easy enough for beginner cooks and great for having your junior chefs help out. I hope you enjoy!
This recipe makes about thirty (30) dumplings, but you may end up with more or less depending on the size of your dumplings.
Step 1: Ingredients:
These are the things you'll need for making your own dumplings:
FOR THE DOUGH:
- 2 1/2 cups of flour (plain/all-purpose)
- Just over 3/4 cup of boiling water
- 1 tsp salt (optional)
FOR THE FILLING:
- About 600 grams of pork mince
- Scallions/green onions/spring onions
- Garlic
- Ginger
- Soy Sauce
- Oyster or Hoisin Sauce (Optional)
-Salt and Pepper
You can customise the filling to suit your taste. That's why I don't give amounts. You can decide how much of each ingredient to put in depending on how much you like it. If you don't like pork, then you can fill these dumplings with whatever you like. Just make sure the filling isn't too moist/wet and it holds together well.
Step 2: Making the Dumpling Dough:
Simply dump the flour in a bowl and mix in the salt if you're using it. I personally don't add salt.
Add the boiling water and mix it with a fork. You will be left with a lot of dry flour and it will look lumpy and gluey and sad. DON'T WORRY. This is normal :) Proceed to the next step and don't add any extra water or you will ruin the dough.
Step 3: Kneading the Dough:
The photos show the dough coming together. You can see how floury it is, but I didn't add any extra water and it turned out perfect!
Step 4: Resting the Dough:
Step 5: Making the Filling:
For the filling, finely chop however many green onions/scallions/spring onions you want. Mince, grate or finely dice however much garlic and ginger you want as well. If you like an ingredient, add more of it, and vice versa.
Mix the pork in a bowl with the green onions/scallions/spring onions, garlic, ginger and 1-2 tablespoons of soy sauce. You can add more soy sauce if you want. I also add 1-2 teaspoons of oyster sauce. Season to taste with pepper, and salt if you really want. Remember the soy sauce is salty already and you will be dipping these in soy sauce as well!
You can also add a splash of sesame oil, or hoisin or fish or oyster sauce if you want. You can add chillies too if you like heat, and basically anything else that you think goes! You can also swap out the pork filling for another filling if you want. Just make sure it isn't too moist.
Step 6: Making Dumpling Skins: (Part 1)
Step 7: Making Dumpling Skins: (Part 2)
If you accidentally tear a skin, simply press the torn edges back together, using a little water if needed to make them stick back together. Keep on rolling! :)
Your dumpling skin should be very thin and translucent. You should be able to see your fingers through it. Thick skins are tough and not so nice to eat (unless you like thick skins, in who case make them as thick as you like!)
Step 8: Making Dumpling Skins: (Part Three)
I like to make half the dough into dumplings skins, then stop and fill those skins before making the next batch from the other half of the dumpling dough.
Step 9: Filling the Dumplings:
If your dumpling suffers a small burst or rupture while filling, take it to the Dumpling Emergency Room! Simply dab some slurry or water over the hole and press a small piece of dough (you can tear a piece from the loose dough at the top or take a spare piece of dough.) and press the 'patch' over the area. If your dumpling suffers a major rupture, it may have to go to Dumpling Reincarnation, a.k.a you will have to remake it.
NOTE: Slurry gives a better 'seal'. You cannot taste it in the finished product.
Step 10: Finishing the Dumpling:
Step 11: Storing and Freezing Your Dumplings:
To freeze your dumplings, arrange them in a single layer on a floured plate and cover loosely with plastic/cling wrap (or leave them uncovered, if that's how you roll!) Freeze them for 30 minutes to an hour (or until they're fully frozen, it's up to you!) This stops them sticking together when you put them in a ziplock bag. Put the partially frozen dumplings into either an airtight box or put them in a freezer-safe plastic bag. I wouldn't keep frozen dumplings for more than three (3) months, but I doubt they will last that long!
Step 12: Cooking the Dumplings:
For the fry/steam method, which results in beautifully crispy dumpling bottoms, pour 1-2 tablespoons of neutral oil, such as Vegetable or Rice Bran, into a pan and turn the heat on medium. Place frozen dumplings into the pan while the oil is still cold to avoid oil splatter when hot oil hits ice crystals. You can put refrigerated dumplings into hot oil however. When the dumplings start to sizzle, take the pan off the heat and wait about 30 seconds to let the pan cool off to avoid oil splatter. Add about 1/4 cup/ 50-60 mls water (hot or cold). Put the pan back on the heat and put the lid on. When the water boils, turn the heat down to medium low or low, and let the dumplings cook for 5-6 minutes or until the water has evaporated, the dumplings are cooked and the bottoms are golden brown. If needed, turn the heat up to high until the bottoms are browned and/or all water has evaporated.
Step 13: Serve the Dumplings!
Step 14: Optional: Easy Dipping Sauce!
For my easy dipping sauce, you'll need:
Soy sauce
Garlic: 1-2 cloves, more if you like garlic and vice versa
Ginger: 1-2 marble sized pieces, more if you like ginger and vice versa
Spring onion/scallion/green onion: As much as you like.
Optional: Black vinegar, chilli slices, chilli oil, oyster sauce
Place the garlic, ginger and spring onion/scallion/green onion in a bowl and cover with soy sauce. Add in some chilli or chilli oil if you like it hot, add a bit of vinegar if you like it sour, etc. It's best to make this sauce at least 5 minutes before you serve to allow the flavours to infuse the soy sauce.
