Criss Cross Quadfish Rubber Band Bracelet
roni_girl 'profile picture'
1.9K32
Intro: Criss Cross Quadfish Rubber Band Bracelet
hey there guys i just joined and it looks like fun! This is my first post so far. I will be posting on how to make rubber band bracelets for right now and then maybe later ill do some other small things along with that. This band that i made is between easy and hard i would probably put it on the hard scale but i dont really know. Any way it is about an half an inch thick so if u want a thick band this will be perfect. If u want to learn how to make this band then just text or email me and ill try 2 help(: follow me and see my posts(: love u guys veronica
STEP 1: Step 1
So for your first step get all your supplies that you'll need--
The supplies you need
-Small Rainbow Loom
- Green and Red Rubber Bands
- A hook
- A c or s clip
You can also use 2 forks instead of a Rainbow Loom if you want to but it is probably easyer is you use a Rainbow Loom.
STEP 2: Step 2
Step 2
So for the second step take 2 rubber bands of your choice of color and criss cross them side by side like a figure eight.
STEP 3: Step 3
Step 3 is now take your next color and make an X using 2 rubber bands as shown.
STEP 4: Step 4
Now after you have done that take your other color or if are only having 2 colors put 2 rubber bands parallel to each other without criss crossing them.
STEP 5: Step 5
Step 5 is now the part were you acually get the band going. So you're going to take your hook thing and grab the bottom rubber band on your loom and loop it up over the peg and let go and it lands on the bands(: Do that for all 4 pegs until there is 2 bands left on each peg.
STEP 6: Step 6
Next do the same thing you did for step 3 make your bands into an X shape. After you have done that loop the bottom band up over the peg just like you did in the last step until all 4 bands are like the picture thats shown.
STEP 7: Step 7
The next step is putting 2 more bands parallel to each other just how u did in Step 4. Now after you have done that pull the bottom band on each peg loop it up over each peg just like you did the other times.
STEP 8: Step 8
Now that you have done the first round its time to do the rest of the band. Start by putting a C or S clip on the 2 bands that you started with or u can just find a way on how you want to do it is up to u. After u have done that start by putting 2 bands parallel to each other criss crossed like a figure eight just as it is shown on the picture and also the first step that u did to start this band. So from now on u will do step 1, 2, and 4 then wants u have done that do Step 6, 7, 8, and 9. Repeat these until the bracelet has reached the desired length.
STEP 9: Step 9
Now wants u have 8 bands on each peg then stop and do the first and second step then for the forth step instead of only taking 1 band u r going to take the bottom 2 bands and loop them up over the peg. And then from now on u will keep doing this. And the band will become a little fatter than when u started so then strech it pretty often and then it will thin out.
STEP 10: Step 10
So now wants u have the desired length that u want , keep pulling the bottom band until u have 1 band on each peg and then pull them onto your hook. Then get your S or C clip and put the four bands on the hook joining the 2 ends.
STEP 11: Step 11
And then the final step is of course putting it on and seeing how it fits. And now u have made a criss cross quadfish bracelet and it was easy. If u like it then email me at lukecoblentz@gmail.com. Hope u had fun making it.
-Veronica (;
2 Comments
Hey thanks. It acually wasn't that hard and handy for something like that.
