Introduction: Crochet Teddy Amigurumi
Little Teddy Bear is the perfect friend for your child, sweet and charming. This bear is approximately 6-8 inches tall in a sitting position depending what on yarn weight and hook size.
My friend had asked me to make for a cute little boy and girl teddy bear. I have used the pattern on ravelry and adjusted the hook size.
Abbreviations:
st = stitch
sc = single crochet
2tog = crochet 2 stitches together
sl st = slip stitch
f/o = finish off
dc = double crochet (used only for toes and thumbs and is optional)
tr - Triple crochet
Step 1: Material
Yarn - 4 ply (Red, black, blue, pink, white)
Crochet hook - 3.5 mm,
Scissors
Needle
Thread
Pair of Eyes
Nose
Fiber fill
Step 2: Head
All the parts of teddy bear are worked parts and then they are sewn together.
1) magic circle or adjustable loop with 6 st (6)
2) 2sc in each (12)
3) 1sc then 2sc in next st (18)
4) 1sc in next 2st then 2sc in next st (24)
5) 1sc in next 3st then 2sc in next st (30)
6) 1sc in next 4st then 2sc in next st (36)
7-14) 1sc in each st for 8 rows
15) 1sc in next 4st then sc2tog (30)
16) 1sc in next 3st then sc2tog (24)
17) 1sc in next 2st then sc2tog (18)
18) 1sc in next 4st then sc2tog (15)
19) 1sc in each st for 1 row
Now you are done with the head portion so you can fill it with fiber fill.
Step 3: Body of Teddy -1
The body is worked up with same MC (6). Same increase and decrease of stitches but avoiding few steps in between will give you the body. But in simple way you can again continue from the head.
If you are continuing from the head follow the pattern below:
20) 1sc in next 4st then 2sc in next st (18) *stuff and shape head.
21) 1sc in next 2st then 2sc in next st (24)
22) 1sc in next 3st then 2sc in next st (30)
23-25) 1sc in each st for 3 rows
26) 1sc in next 4st then 2sc in next st (36)
27) 1sc in next 5st then 2sc in next st (42)
28) 1sc in each st for 1 row
29) 1sc in next 5st then sc2tog (36)
Step 4: Body of Teddy -2
You can use the color change of yarn as you like. I added white yarn in the body.
30) 1sc in next 4st then sc2tog (30)
31) 1sc in next 3st then sc2tog (24)
32) 1sc in next 2st then sc2tog (18) *stuff and shape body. By this time you can start stuffing the body.
33) 1sc then sc2tog (12)
34) 1sc then sc2tog (8)
35) sc2tog twice then f/o and use yarn tail to weave in and out of the remaining stitches, pull tight to close the gap, knot off and hide yarn tail inside the body.
Step 5: Ears
The ears are made with the pattern below. It is then folded into half and sewn at place. Make 2 of them.
1) magic circle or adjustable loop with 6st (6)
2) 2sc in each (12)
4) 1sc in next 5st then 2sc in next st (21)
5) 1sc in next 5st then sc2tog (18)
6) 1sc in next 4st then sc2tog (15)
7) 1sc in each st for 1 row
Step 6: Snout
Snout:
2) 2sc in each (12)
3) 1sc in each st for 1 row sl st next st and f/o leaving a long tail for sewing.
Add a nose that you get from stores. Or you can embroider too.
Step 7: Arms
Arms - Make 2
2) 2sc in each (12)
3) Do Sc in each stitch around
Repeat step 3 for 3 times.
Fasten off. Stuff with fiber fill.
Step 8: Legs
Legs - Make 2
2) 2sc in each (12)
3) *1sc, 2 sc* Do * to * aorund (18)
4) Do Sc in each stitch around
Repeat step 4 for 4 times.
Step 9: Time for Assesmbling
Sew in the ears, the legs and the arms in place. Fill the snout little with fiber fill and sew it.
When all your parts are set in, add the eyes in place. Add the nose at the snout and you can embroider the nose.
Step 10: Dress Up Your Teddy - Hat
I have made a boy and a girl teddy. For the boy I made a hat.
Hat: Black
1) MC - 6 Sc in the magic circle
2) 2 Sc in each stitch around - (12)
3) In front loop alone - Sc around
4) Sc around in each stitch - (12)
Repeat 4 till the height of the hat needed.
Step 11: Dress Up Your Teddy - Bow
Make a magic ring.
Ch 5, 3 tr in ring, ch 5, sl st in ring, ch 5, 3tr in ring, ch5, sl st in ring.
Cut yarn leaving a tail at least a few inches long. Sew end through the first ch stitch at the very beginning and finish off.
Step 12: Girl Teddy
In the same way you can dress up your lady love teddy also the same way. Add some flowers. Be creative your way.
