Introduction: Crochet a Girl's Ladybug Cuff Bracelet
This cute bracelet would make the perfect gift for any girl -- toddler to 'tween and beyond. The ladybug is removable and makes a cute carry-along playmate or make the ladybug alone and use it as a back pack decoration. The possibilities are endless!
Note: The ladybug cuff bracelet pattern is my original design. To see more of my work or get copies of other patterns I've written, please visit my blog or Ravelry Pattern Shop. I also sell finished amigurumi in my Etsy shop.
Thanks for checking out my instructable and happy crocheting!
Karla (The Itsy Bitsy Spider)
P.S. You're welcome to use this pattern as you wish -- for love or for money. But, please respect my work and do not claim this pattern as your own. And, if you have the means to do so, give me a little shout out when you use it. Thank you!
Step 1: Getting Started
To make my ladybug cuff bracelet, I used the following materials:
Note: These instructions assume that you know the following crochet stitches:
- Worsted weight acrylic yarn in red and black
- Size E (3.5 mm) crochet hook
- Two buttons (one shirt button-sized and one about the size of a dime)
- Hand quilting thread
- Tapestry needle
- Sewing needle
- Stitch marker
- Scissors
- Chain
- Slip Stitch
- Single Crochet
- Single Crochet Decrease
Step 2: Spots
To make the spots for your lady bug:
Round 1: Attach your yarn to the hook with a slip knot and chain two. Make four single-crochet stitches in the second chain from the hook. Join the ring with a slip stitch in the first single crochet made and finish off, leaving a tail for sewing.
Make two spots.
Make two spots.
Step 3: Body
To make your ladybug's body:
Round 1: Attach your yarn to the hook with a slip knot and chain two. Make six single-crochet stitches in the second chain from the hook. Place your stitch marker in the last (6th) single crochet.
Round 2: Make two single-crochet stitches in each single crochet from the first round. Move your marker to the last (12th) single crochet.
Round 3: * Make two single-crochet stitches in the first stitch from round 2, then make one single crochet in the second stitch from round 2. Repeat this pattern from the * all the way around. Move your marker to the last (18th) single crochet.
Round 4: * Make two single-crochet stitches in the first stitch from round 3, then make one single crochet in each of the next two stitches from round 3. Repeat this pattern from the * all the way around. Move your marker to the last (24th) single crochet.
Rounds 5-6: Single crochet in each stitch around. Move your marker to the last (24th) single crochet.
Stop here and sew the spots onto your ladybug using the tapestry needle. You should space them the same distance from the center of the piece. Hint: I put my spots at roughly round 2.
Round 7: *Decrease across the first two stitches and single crochet in each of the next two single-crochet stitches. Repeat this pattern from the * all the way around. Move your marker to the last (18th) single crochet.
Round 8: *Decrease across the first two stitches and single crochet in the next single-crochet stitch. Repeat this pattern from the * all the way around. Move your marker to the last (12th) single crochet.
Round 9: *Decrease across the first two stitches. Repeat this pattern from the * all the way around and finish off, leaving a tail for sewing.
Step 4: Finishing the Body
- Using the tapestry needle, gather the remaining six stitches on the back of the ladybug's body and pull tight.
- Push the needle through the center of the piece until it pokes out on the top side (see the first image, below).
- Pull the needle all the way through and pass it back through to the back side of the piece (see the second image, below).
- Make a loop on the back of the piece only slightly larger than the button you will use to attach it to the cuff bracelet (see the third image, below).
Step 5: Head
To make the ladybug's head:
Round 1: Chain four. Work two single-crochet stitches in the second chain from hook, one single crochet in next, and four single-crochet stitches in the last stitch. Rotate your work 180 degrees. Working in the back loops now, make one single crochet in the next stitch and two single-crochet stitches in the last stitch. You will end up with an oval-shaped round with ten total stitches.
Rounds 2-3: Single crochet in each stitch around.
Finish off after round three, leaving a tail for sewing.
Step 6: Attach Head
- Using the tail left over from the head and a tapestry needle, attach the head to the body (see first image below).
- If desired, use the remaining length of tail to add antennae to your ladybug (see second image below). Make sure to knot the ends of the antennae to ensure that they do not slip through the head.
Step 7: Cuff
Before beginning this step, get a general wrist measurement for the girl who will wear the cuff bracelet. To do this, wrap a piece of yarn around her wrist and use it as a guideline.
Note: If you are making the cuff bracelet for someone under three, leave a little extra room to slide the bracelet over the wearer's hand. Typically one or two rows will work if you are using a stretchable acrylic yarn. See Finishing for People Under Three on step/slide 10 for more details.
To make the cuff bracelet:
Row 1: Chain six and turn. Single crochet in the second stitch from hook and in each across (5 single-crochet stitches).
Row 2: Single crochet in each stitch across. Chain one and turn (5 single-crochet stitches).
Repeat row two until you reach the desired length for your bracelet. Finish off and weave in ends.
Step 8: Finishing the Cuff Bracelet
- Join the red yarn at one corner of the cuff bracelet and single crochet evenly across one of the long sides of the bracelet.
- Work two single-crochet stitches in the corner, rotate 90 degrees, and work one single-crochet in the next stitch. Chain three (or more, depending on the size of the button you will be using to close the cuff), single crochet in the next stitch, and work two single-crochet stitches in the corner. Rotate 90 degrees. Single crochet across to the end of the other long side evenly and finish off. Weave in ends.
Step 9: Attach Buttons
Note: Skip this step if you are making the cuff bracelet for a child under the age of three. See Finishing for People Under Three on slide/step 10 for more details.
- Using needle and thread, attach the larger button near the center of the cuff bracelet (as shown in the image below).
- Attach the smaller button nearer to the end of the cuff bracelet.
Step 10: Finishing for People Under Three
Instead of using buttons to make the ladybug removable, sew the ladybug body directly to the end of the cuff bracelet. Then, wrap the bracelet around to make a loop and stitch the two ends together.
Tip: You can also use hook and loop tape to secure the end of the bracelet to make it easier to get on and off.
Your toddler may not be able to slide the bracelet on and off by herself, but my two-year-old still had a lot of fun fidgeting with it!
Step 11: More in This Series
If you liked my ladybug cuff bracelet, be sure to check out my Turtle Cuff Bracelet instructible too!
Thanks for stopping by!
