Introduction: Cube of Life
Our system aims to solve the problem of the astronauts constantly needing to water the plants manually. Using a cubic design optimizes the spacing of each of our variables and gives the plants enough room to grow without imposing issues. The system allows the water to dispense on a timer, rather than needing to water them manually every few hours.
- Plastic Glass
- Silicone
- 2 Timers
- Tubes
- Rockwool Cubes
- Automatic water pump with pressure switch
- Electric Fan
- 2 Red LED Strips
- 2 Blue LED Strips
- 1 Green LED Strip
Step 1: Innovations in Our Design
- Incorporate 2 shelving units to fit more plants.
- 2 Perforated tubing connected to the reservoir to water plants evenly.
- Water release runs on a timer, watering the plants with the required amount every few hours.
- Pressurized electric water pump to push water through the tubes and into the rockwool.
- Electric fan on a timer to regulate humidity.
- Purple hued LED strip lights on the corners of the system. Additional green LEDs on the sides.
Step 2: Growth Medium
Similar to a hydroponic system, the lettuce is placed in separate rockwool cubes. The medium itself needs to be soaked in a condition solution that has a pH of 5.5, which then lowers the pH of the rockwool cubes to about 6.0. While the cubes are absorbent, the water runoff shouldn’t exceed more than 30%.
Step 3: The Design
Step 4: 3D Model
The Dimensions
50x50 box
12 cm of LED strip lights
Height of 15 cm for water
Height of 17.5 cm for each shelf (35 cm for two shelves together)
