Introduction: Custom Made Jewelry for the Wedding Party!
About: MA art education BFA photography
{"context":{"you-image":{},"spinner":{"jQuery110202950669401424194":404},"location":{"href":"https://www.instructables.com/editInstructable/edit/EGX2GL6IEGXTKUR/step/0","origin":"https://www.instructables.com","protocol":"http:","username":"","password":"","host":"www.instructables.com","hostname":"www.instructables.com","port":"","pathname":"/editInstructable/edit/EGX2GL6IEGXTKUR/step/0","search":"","hash":""},"jQuery110202950669401424194":1,"gtmHasClickListenerTag":true,"b":{"sizzle-1442281771496":{"parentNode":["80498 618",351]}},"h":{}},"selector":"#editor-Object-5"}
Step 1: Decide on Design
choosing the right shape for the design is key.Be careful not to make it too complicated.
Step 2: These Are the Tools/supplies You'll Need to Transfer Design Onto Copper Blank or Sheeting
If you are wanting to transfer text- you can use image transfer by printing on a transparency and ironing it on to the copper ink side down
Step 3: Next Is to Prep the Copper for Saltwater Etching
you need to first take distilled water- approximately 4 cups that you have put 2 cups of iodized salt into- and boiled on a stove to get fully dissolved.
put it into an aluminum serving pan-loaf tin will work- and put salt water into the pan.
Then take a piece of coated copper wire and tape it onto the back of the designed copper piece and place it where it floats on top of the salt water- I use chopsticks and sandwich the wire in between the chopsticks to hold it up.
Step 4: You're Ready for the "Juice"
hook up the red- anode wire to the side of the pan, and the canoed/white wire to the other end of the copper wire you've placed through the chopsticks
wait from 15-20 minutes before you take the copper out
Step 5: You'll Need to Use a Jewelers Saw to Cut the Excess Copper Off- and a File to Smooth Rough Edges
Step 6: Choose Stones And/or Charms to Add for a Personalized Touch
stones with holes- can be wire wrapped and made into a charm that has symbolic or otherwise personal touch
