Introduction: Custom Rotational Window Panel
Prototyping Steel -
The Custom Rotational Window Panel is a part of a one-to-one scale detailed window section prototype from a larger voronio pattern. This project utilizes multi-material fabrication tools and techniques through parametric design. By using water-jet steel plates, stock steel tubes, ply-wood, glazing and rolling hardware, we explore not only the collaboration of each fabrication process, but also the complexities of operable features in physical architectural components.
Component needed:
-1/8" walnut ply wood x1
-1/8" acrylic x1
-1/8" Ply wood x1
-1/2" Ply wood x1
-1/4" Ply wood x1
-1/8" steel plate x1
-Thrust bearing x1
-Bolts 1/4" x19
-1/2" x 1/2" Steel Tube x3
Step 1: 2D Cut Line
We have use voronoi command on grasshopper to make the face plate cad layer. However users are free to change shapes of the frame
Prepare the Cad file in two layers:
-Face plate
-Spacer
Step 2: Digital Fabrication
Run the File on
Laser cut machine for:
-1/8" walnut ply wood x1 (for face plate)
-1/8" Ply wood x1
-1/2" Ply wood x1
-1/4" Ply wood x1
-1/8" acrylic x1
Water jet for:
-1/8" steel plate x1 (for face plate)
Step 3: Manual Fabrication of the Frame: Tube
Cut the tubes 45 degree according to the length of of the face plate
Step 4: Weld the Tubes
Miter joint the tubes together with mig weld
Step 5: Grinding
Grind the welds into right angle
Step 6: Drilling
Drill though the face plate and the tube together to make sure the holes are in line.
Turn the tube around and drill again for inserting the tube
Step 7: Tapping
Tapped the steel face plate in a quarter inch drill
Step 8: Insert Pins
Drill a hole through spacer and the tubes than insert a pin with a trust bearing in the inner frame
Step 9: Sandwich the Layer on to the Tubes
Put the layer together in the order of
-Steel Face plate
-1/8" ply wood spacer
-1/8" acrylic
-1/4" ply wood spacer
-1/2" ply wood spacer
and locked them together with the nuts and bots together through the tubes
Step 10: Assembly the Rotating Window
Repeat the sandwiching process with the rotating window and locked them up in together with nuts and bolts
Step 11: Rotate the Window
