Introduction: Custom Wall Molding
About: Educated as an architect. Employed as a builder. Always a maker. https://www.instagram.com/muldoon_made/
This project aimed to add some depth to a large wall above the beds in our kid's room.
- 4x8 sheet of mdf
- Saw for cutting straight lines (table saw or circular saw)
- Saw for cutting curves (jig saw)
- Router to add profile to the molding. Adding this to a router table is the easiest way to rout the strips.
- Nail gun to attach to wall
- Caulk and paint
Step 1: Design & Layout
We designed the molding to establish the zone for the beds. The curve adds a playful shape and will be accented with a new wall light.
Step 2: Cut MDF
Break down the mdf to cut all the straight strips that you will need. We cut them into 2-1/2" strips. Keep the rest of the sheet to use as the curved pieces. (If you do not have enough space, you may need additional pieces)
Step 3: Establish Curve
I used a nail and string to establish the radius for my curve. I positioned the mdf so I could draw the radius at the correct length.
Step 4: Cut Curve
I used a jig saw to cut the drawn curve. Sanding was needed to smooth out the shape.
Step 5: Dry Fit
I made sure I was happy with the design by laying it out before install. I left the curve long and made the final cuts once all of the straight pieces were installed. this allowed me to make up for any human errors or wall inconsistencies.
Step 6: Rout Profiles
I used a roman ogee bit and a router table to add a profile to the inside and outside edges of the 2-1/2" molding.
Step 7: Install
I used a brad nailer to attach the molding to the wall. Edges were caulked and the molding was painted to match the wall color.
Step 8: Finish
We enjoy the added design element that this gives the room.
