Introduction: Cute Crochet Devil (pattern)
About: crochet and knitting lover
Learn how to crochet a beautiful little crochet devil, here you have the pattern and specific instructions. Each of the steps listed describe the pattern of each row, you have a photo for each of these steps.
At the end of each instruction in square brackets is the number of stitches that you should have left for each row.
- Red and black macramé yarn (1.5 mm diameter 100% acrylic)
- Crochet Needle
- Synthetic filling
- Scissors
- Yarn Needle
- 10mm plastic eyes x2
Step 1: LEGS
- Base ring of 6 stitches [6].
- One stitch per hole, change color on the last stitch [6].
- One stitch, then increase all the way around [9].
- One stitch per hole [9]
Note: Make two legs and to one of them, knit a chain in the loop of the last stitch.
Step 2: BODY
- Join the two legs with a stitch, starting from the chain of the last leg, knit a stitch through each hole and every time you go through the chain, 9 stitches per leg and 1 when you go through the chain [20].
- 8 stitches and then a decrease, change color on the last stitch [18]
- One stitch per hole [18]
- 4 stitches and then a decrease [15]
- One stitch per hole [15]
- 3 stitches and then a decrease [12]
- 2 stitches and then a decrease [9]
Note: when you finish the sixth row fill in the body, you can use a pencil to put the filling in, if you leave it to fill in later, it will be more difficult.
Step 3: HEAD
- An increase in each hole [18]
- 2 stitches and then an increase [24]
- 3 stitches and then an increase [30]
- One stitch per hole [30] 1 stitch per hole [30]
- 3 stitches and then a decrease [24]
- 2 stitches and then a decrease [18]
- One stitch and then a decrease [12]
- 6 decreases and then closes the head by joining the holes [6]
Note: when you finish the eleventh round, fill in the head.
Step 4: ARMS
- Knit a base ring of 6 stitches [6]
- One stitch per hole [6]
-One stitch per hole [6]
- Flatten the arm and knit 3 stitches to close the arm (one stitch taking the next hole and the one on the other side of the arm) [3]
Note: Make 2 arms
Step 5: TAIL
- Knit a base ring of 5 stitches [5]
- One stitch per hole, finish off with a slip stitch and a chain [5]
Step 6: EARS
- Make a base ring of 5 stitches [5]
- An increase in each hole [10]
- One stitch and then an increase, finish off with a slip stitch and a chain [15].
Note: Make 2 ears
Step 7: HORNS
- Make a base ring of 6 stitches [6]
- One increase then 5 stitches [7]
- One stitch per hole [7]
- One increase then 6 stitches [8]
- One stitch per hole, finish with a slip stitch and a chain [8]
Note: Make 2 horns
Step 8: ASSEMBLY
- Join both arms to the body at the shoulders.
- Join the tail to the body at the back, cover the color change with it.
- Attach the horns to the top of the head as shown in the pictures, when finished bend them to give them the curve.
- Join the ears, just below the horns on the sides of the head.
Note: be careful in the details of the joining and make sure it can't come loose.
Step 9: FACE
- Glue the eyes as shown in the photos, at a height between the sixth and seventh turn of the head, do not leave them so close together.
- Sew a "W" shaped mouth with black thread, centering it between the eyes and one turn below them.
- Finally, sew a 5-pointed star on the forehead as shown in the photos.
Note: it is important that you secure the ends so that the seams do not come loose.
Step 10: FINAL CUTE DEVIL CROCHET
This is how our beautiful little devil looks like, knit one for you or for a special person, and enjoy it.
