Introduction: Cypherbot (an Assistant Robot)
Cyphersoft is an assistant robot that can be your friend and help you while you work. It can talk and walk. You can customize and use it for anything you can imagine. Now you can make an intelligent robot with just an Arduino and Raspberry Pi.If you have any suggestions to improve this robot then please suggest in comments
1.Raspberry Pi (any model will work except zero)
2.L293D IC or L293D Motor driver shield
3.USB Mic
4.Raspberry Pi TFT Screen(3.5 inch)
5.MDF Board or Cardboard
6. Servo motors (x6)
7. B.O. Motors (x 6 or 4 )
8.Glue Gun
9.Arduino(any model will work)
10.USB Webcam
Step 1: Designing
Any chassis will work
The face design template is given above
Step 2: Code
Download the code using the following command
git clone https://github.com/cyphersoft/Cypherbot.git
open the cypherbot folder and copy the folder contents in the home directory
Step 3: Installing Dependencies
Enter Following commands:
1.chmod +x install.sh
2../install.sh
Step 4: Configuring the Audio Settings
Follow the following steps-
1.Enter following command- sudo nano /usr/share/alsa/alsa.conf
2.Scroll down until you find the lines
defaults.ctl.card 0
defaults.pcm.card 0
3.Change them to
defaults.ctl.card 1
defaults.pcm.card 1
4.Press ctrl+x and press y to save configuration
Step 5: Circuit
Circuit diagram for the robot
Step 6: Motor Assembly
Step 7: Assembling the Robot
Step 8: Upload the Ino File to Arduino From Cypherbot Folder
Step 9: Run the Python Script to Make Robot Work
Run command-python3 cypherbot.py
The robot will start running
If anyone faced a problem making this then please let us know in comments so we can help
