Introduction: DANCING LED WITHOUT ANY IC,CAPACITOR OR TRANSISTOR
About: HI GUYSSS...I AM THE STUDENT OF CITY MONTESSORI SCHOOL CHOWK MY GOAL IS TO MAKE ELECTRONIC CIRCUITS WITH AS LESS COMPONENTS AS POSSIBLE. I'M EXPERIMENTING AND WORKING ON THE SAME. I HAD SUCCEEDED IN MAKI…
HI FRIENDSSSSS.....
This project work on simple LED series cuircit
BUT Tri colur led blinks it self which allows the current to pass on its own oscillation as a result the whole LED series show dancing effect .
Hope you like it.
(((((((((IF YOU LIKED IT COMMENT FAST OR IF YOU DIDN'T UNDERSTOOD ANY STEP ASK ME IN COMMENTS)))))))
Step 1: THINGS TO BE NEEDED
For this awsome project you will need
3 led(Tri colour led (recommended) blue and green (optional) .).
Bread Board.
9 v battery.
Battery holder
Note: you should have Tri colour Led as without this you can not build this project
Step 2: CIRCUIT DIAGRAM
On the basis of the same circuit diagram we will be constructing our project
Step 3: FIRST STEP
Take your circuit board and check each hole of it so that no problem occur in future in making the circuit
Step 4: INSERTING FIRST LED
Insert the blue LED in one of the hole of circuit board
Step 5: INSERTING SECOND LED
Insert the Tri colour LED in the circuit board and insert +ve terminal of Tri colour LED to the -ve terminal of blue LED
Step 6: INSERTING THIRD AND THE LAST LED
Now insert the green LED in the circuit board and connect the +ve end of green LED to the -ve terminal of Tri colour LED
By completing these steps you will be having +ve terminal of blue LED and -ve terminal of green LED
Step 7: CONNECTING BATTERY HOLDER'S WIRE TO THE CIRCUIT
Connect the +ve (red wire) to the +ve terminal of blue LED and -ve (black wire) to the -ve terminal of green LED
Step 8: PROVIDING POWER TO THE CIRCUIT
Now connect the Battery to battery holder
Step 9: RESULT
You will be having the dancing LED without using any IC OR CAPACITORS OR EVEN ANY TRANSISTORS
Step 10:
http://m.youtube.com/watch?v=QjiJgSN1uDo
