Introduction: DIY 3D Body Scanner Intro.
The tools needed for this project include: Laser cutter (50 watt), Drill press, Power miter, box Table, saw Tap & die set (#25 drill bit & 10/24 NC tap) assorted twist drills, assorted spade bits, hole saws, forstner bits and assorted hand tools
The materials need for this project, their prices and where to buy them are included in the jpg.
The original design for this 3D body scanner was created by: David Tinapple, Professor at Arizona State University.
Collaborators for this project include: Dan Collins Professor at Arizona State University, Shahabedin Sagheb MFA Candidate at Arizona State University and Andrew Noble MFA Candidate at Arizona State University
Step 1: Prepare Main Structure.
Cut the 4 x 8 plywood sheet into the following parts:
a. base. 2’ x 2’ (1).
b. vertical mast back 7’ x 8” (1).
c. vertical mast sides 7’ x 4” (2).
d. rod bases. 9 1/2”x11 1/2” (2)
e. get two 8’ x 3/4” rods
Step 2: Step 2. Prepare Rod Bases
a. Drill two 3/4” (25/32”!--big enough to allow rods to pass, but not be sloppy) holes 6 1/2” apart on bottom rod base. 3/4” from top and side.
b. Drill two 3/4” holes 6 1/2” apart on top rod base. 3/4” from top and side
c. Drill one 3/4” hole in center of top rod support 3/4” from top
Step 3: Step 3. Assemble Mast
a. glue and screw mast sides to back of vertical mast using 5/8” sheet rock screws.
b. glue and screw rod base to top and bottom. make sure the three hole base is on top. (we faced the open part of the vertical mast away from the front. the open channel facing the back was used to to store the pulley system and hide the wires. see reference below)
c. wedge in the two vertical rods (you should be able to slightly bow rods to fit them in).
Step 4: Step 4. Assemble Scanner Carrier
a. cut wood 8” x 8” (2)
b. cut wood 6” x 6” (1)
c. drill together all three carrier pieces
d. add velcro to the two sides of scanner support that will ride the rods (to limit friction when pulley system is raising and lowering scanner support on the rods.)
e. screw in two L brackets on top of scanner support to loop thread through
f. drill 1” hole through all of scanner support to allow scanner cable to go through
Step 5: Step 5. Digitally Create Turntable Gears
a. access online gear generator software at http://geargenerator.com/ to see how we generated gear files.
b create switch boards for verticle mast (5 1/4” x 6”) and lazy susan. (3” x 6.5”)
Step 6: Step 6. Laser Cut Parts
a. Use laser to design the generated gears from Step 5: on 1/4” plywood or MDF (or acrylic if you have that capability). (4 different gears)
b. Use laser to make the switch board for vertical mast (1) 5 1/4” x 6”. include holes for: up/off/down; pox; and motor: on 1/8” Masonite (1)
c. Use laser cutter make the switch board for Lazy Susan (1) 3” x 6.5”. include holes for: on/off; pox: on 1/4” plywood or MDF (1)
Step 7: Step 7. Wire Lazy Susan and Pulley System
a. wire and solder pulley system’s toggle switch (DPDT); potentiometer; and motor;
b wire and solder Lazy Susan’s toggle switch (DPDT); potentiometer; and motor;
Step 8: Step 8. Make Pulley Device
a. cut 2” diameter Schedule 40 PVC pipe: 6” piece (1)
b. drill 3/16” hole in center of both PVC pipe caps (use jig to aid in centering if necessary)
c. insert 9” long x 10-24 diameter threaded rod into drilled PVC caps and pipe (#10 wire size / 24 threads per inch).
d. allow for 1” of threaded rod to stick out on each side of PVC pipe. You will lock PVC to threaded rod with 10-24 nuts.
e. connect right side of threaded rod to pulley motor with 10-24 hex coupling. (You will need to drill and tap one end to receive 10-24 x 3/16” socket headed set screw. This end will be locked to motor spindle. The other end will be threaded onto axle and locked with 10-24 nut)
f. Drill flat bracket on opposite side of mast to level the PVC pipe horizontally
Step 9: Step 9. Assemble Pulley System
a. mount one sliding door pulley above center hole of vertical rod support. mount one sliding door pulley at top center edge of vertical mast. Both pulleys should clear the wood. Pulley will be used to guide the thread and limit tension.
b. attach thread to PVC pipe; turn on motor; wind thread tightly.
c. bring thread up to top of mast, over both pulleys and down the entire length of the mast.
d. attach thread to Scanner Support.
Step 10: Step 10. Assemble Lazy Susan
a. attach 12” Lazy Susan (circular ball bearing assembly) to 17” gear
b. mount the 12 VDC motor, 1.2 amps motor with the switch board for Lazy Susan (1) 3” x 6”. attach to small gear #4. mount on base board.
c. glue gear #2 and gear #3 together. align in center. (Burn guidelines using laser when you cut the gears).
d. drill 1/4” hole through 2/3 gear assembly and through baseboard. Countersink hole on bottom side of baseboard. Use 1/4 x 2” stove bolt as axle to pin 2/3 gear assembly to baseboard.
e. Do NOT pin gear #1 (large 17” gear) to baseboard. The weight of a body standing on the turntable is sufficient to hold it in place. Plus, this provides a measure of safety for exposed gear teeth. If pants or fingers get caught in teeth of large gear, the gears will simply spread apart.
Step 11: Step 11: Capture a Scan
Find a friend, connect the scanner up to a computer with Skanect software and capture some 3D Data!
