DIY 5V Linear Regulator
1.7K32
Intro: DIY 5V Linear Regulator
This is a 5v linear voltage regulator circuit.Input voltage should not be more then 35V.
STEP 1: Test It on the Breadboard
Parts List :
1) LM7805
2) 100 nF (ceramic capasitor)
3) 10 uF (electrolite capasitor)
4)100 uF (electrolite capasitor)
5)Breadboard (optional)
STEP 2: Connecting the Parts
Now put your LM7805 on your breadboard pin 1 is input voltage pin 2 ground pin 3 is output voltage
positive part of the 10uF capasitor should be connected with pin3 and a 100nF capasitor will connected with this in parallel. Then the positive part of the 100uF capasitor should be connected with pin1. The circuit is done.
2 Comments
For many circuits, you don't even need the capacitors. Those are just necessary for sensitive circuits that need a really steady power supply.
Thanks for your advice its just for taking extra precaution...
