Introduction: DIY BATTERY CAPACITY TESTER
Hello guys
I hed some old li-ion batteries. which is recycled from laptop batteries and powerbanks. i want to know what it's actual capacity. that's why i decided to make battery capacity tester.
this version can test li-ion batteries. stay connected for future version for such big updates...
this is based on atmega8 MCU.
I use 16x2 lcd to display parameters like voltage, current, capacity(mAh).
and i also use EXTERNAL voltage reference for good accuracy.
you can Watch video on YouTube: click here
Step 1: Parts and Components You Need...
this components you need:
- ATMEGA8
- 16Mhz crystal
- 22pf capacitor
- 10k resistors
- 22k resistor
- 470 ohm resistor
- bc547 transistor
- lm1117-adj regulator
- 10k preset
- 1k preset
- 5v relay
- 104j (0.1uf) capacitor
- 10uf capacitor
- 16x2 lcd display
- tl431 voltage reference
- 2.2k resistor
- 5v buzzer
- 1n4007 diode
- LM358
- IRLZ44 (or logic level MOSFET);
- 1ohm 5W shunt resistor
- PCB
- micro usb socket(female)
Step 2: Circuit Diagram
this here is the circuit diagram:
make all connection according to diagram
Step 3: Upload the Code
you can use any arduino in this project i use atmega8
for code: click here
Step 4: Let's Use It...
i tested it and it works perfect.
i measure current and voltage in multimeter also
this is the readings
battery tester
v: 4.03
current: 0.70
multimeter readings:
v: 4.07
current: 0.74
overall this is very good.
thanks
make it and share your experience. if you have any query feel free to comment it.
